Stealth P2P network hides inside Kazaa
Apr 5, 2000
13,256
It probably set itself as a system file. Go into DOS again, type:
attrib -h -r -s (file) to get rid of all protections on the file and you should be able to delete it
Martin
29,178
<< It probably set itself as a system file. Go into DOS again, type:
thanks, I'll try that .
nullshark
2,235
Check your msconfig startup tab for anything referencing BDE, aswell. I it's mentioned in there it means that some BDE thing is running and that's prob why you can't uninstall it. uncheck it (or delete mention of it in the RUN keys in the registry) and reboot, should be able to delete then.
Worked for me :)
hudster
809
I have KazaaLite, and running WinXP, and I can't seem to find a trace of it on my system (thankfully)
Nefrodite
Banned
Feb 15, 2001
7,931
what the, i just cut and paseted the bde folder without any trouble at all. am i a super user or something? hehe. :p wasn't that hard. i don't have kazaa loaded right now ofcourse:p
DanFungus
5,857
<< I was wondering what that b3s was in my add/remove programs...but it wont let me uninstall it!!??
I am going to download the latest AD-Aware and see if that hoses it. We need to find a solution for this folks...
try closing Kazaa...
Im serious...I tried Add removing it, and no go, then I closed Kazaa, and it removed itself. Those bastages :|
DanFungus
5,857
ALSO:
goto start>run>type in regedit
click the plusses on all of these:
My Computer
HKEY Local Machine
SOFTWARE
Microsoft
Windows
Current Version
Run
and delete the b3d Update--everytime you bootup, it does this:
C:\WINNT\BDE\Update\Zupdate.EXE -silent -p "C:\WINNT\BDE\Update" -s setup.cab
I hate this company!
Linux23
11,374
741
WTF, i have this sh!t on my XP desktop and my laptop. weird thing is, i didn't install Kazaa on my desktop!:Q
GTaudiophile
29,767
33
Who has dumped Kazaa as a result of BDE?
Going to START>SEARCH>FIND FILES OR FOLDERS...
I searched for "bde" on my C:\ drive and came up with the following files in the C:\WINNT\system32 folder:
(All are from BDE Corp.)
bdeverify.exe
bdeverify.dll
bdesecureinstall (x2)
bdeinstall
bdeinsta2.dll
bdefdi.dll
bdedownloader.dll
bdedata2.dll
Anyone know if it's safe to delete these files?
db
10,575
292
There must be some way of ramming this situation up Brilliant's ass.
GTaudiophile
29,767
33
<< Going to START>SEARCH>FIND FILES OR FOLDERS...
bdeverify.exe
bdeverify.dll
bdeinstall
bdeinsta2.dll
bdefdi.dll
bdedownloader.dll
bdedata2.dll
gplanet
729
whoever said that they risk "losing all their users" is very wrong.
the average kazaa user is a dumb college girl who just found out about the program and decided to use it instead of Napster! the average kazaa user also believes that kazaa is the only way to download anything on the internet
GTaudiophile
29,767
33
<< the average kazaa user is a dumb college girl who just found out about the program and decided to use it instead of Napster! the average kazaa user also believes that kazaa is the only way to download anything on the internet >>
Buwhahaha! So true! The week before last, a girl at Tech was "busted" for setting a new campus record for most bandwidth used on one connection in one day: 56GBs!
Apr 5, 2000
13,256
<< Urgghh! Has anyone deleted those BDE files successfully??? >>
YES they are safe to delete (if you right click and go to Properties -> Version tab, they all say Brilliant Digital on them. If you don't have their BDE crap on your system anymore you don't need those files anymore)
PowerEngineer
3,607
787
<< I'm running Kazaa Lite on Win XP and I have no sign of this at all... >>
I've also installed Kazaa Lite (on W2K Pro) and can't find any of the bde* files on my system. :eek:
Nefrodite
Banned
Feb 15, 2001
7,931
norton windoctor found all the reg entries:p just told it to delete em all. no bad effects so far:)
Ultima
2,893
Um, I never had a problem uninstalling it. Just close all IE windows and any other program that might be using IE (Like kazaa, duh ;)). and wait a little bit.
