Looks a bit better. A few more suggestions:
1. Might just be the camera angle, but the depth still looks questionable.
2. You're looking down with your eyes but your neck is still arched. To fix your neck position, imagine holding a tennis ball under your chin by squeezing it down to your chest (SS has a good illustration of this).
3. I'm not sure you are driving out of the hole correctly. It doesn't look like you are engaging your hip extensors (hamstrings, glutes, adductors) much and are doing a quad centric leg press type motion. To fix this, do the drill in
this video: squat down, have a friend stand behind you and push straight down on your lower back, and then try to squat back up. If you can stay in balance while doing this, you'll find that you start driving out of the hole by driving your ass/hips
straight up. In fact, driving your ass up is the
only thing you should think about - your knees/quads/etc will take care of themselves.
You're getting closer. Keep working on it and you'll have a good squat soon.
