Bill Brasky
I see no reason to turn it off. I've had a stable overclock for 2 years with speed step enabled.
I'm pretty sure you don't have a clue what you are saying, don't listen to this OP it is utter rubbish. The only time you should turn it off is if you are going for insane OCs on LN2.
Example.. (not working) ur running a multi of 10 with a bclk of 200 vs stock 100. In short that gives u 2ghz instead of 1ghz. When speedstep kicks in it drops just the multi to 8, and still leaves the bclk at 200mhz... which then u go down to 1.6ghz. instead of the factory set 800mhz. The voltage is dropped to lower then stock values, and if u dont have a nice chip, it will BSOD at 1.6ghz with the voltage speedstep defines, because that idle voltage was locked for 800mhz... and ur trying to run 1600mhz.
Once mobo mfgs figured it out, that is.Ever since Core 2 EIST hasn't affected in any way the max stable overclock you'll be able to get from a CPU
EIST saved me ~30 watts when just sitting here in idle. ADding dynamic vcore only saved me another 5 watts or so. I was surprised because I thought Power is related to ~CFV^2 so reducing voltage should have far more of an effect. I suppose the cpu is idle anyway with EIST, so the reduced voltage doesn't do that much.But for the most part it is not running at 4GHz if you have C3/C6 enabled. You may find that for more than 90% of the time the clocks are stopped and the cores / package are in a low power state. It only runs 4GHz in short bursts.
DLeRium, you can get an idea of how ineffective EIST is here. The savings for using EIST with C3/C6 vs just C3/C6 are in the order of less than 2W. With EIST disabled the full power of the CPU can be had much quicker. IIRC with W7 default balanced power plan EIST will take some 30ms before transitioning from the lowest performance state to the next highest state. For some people that may mean seeing stutter effects but of course YMMV and in the end it's up to you. IMHO though EIST on todays CPU's is much overrated when it comes to power saving and offers next to no benefit when using the power saving features of higher c-states.
Your wrong [redacted] I know exactly what IM saying,, your the clown. [redacted]
Whats your problem? Youve been a dick to anyone that youve quoted for days now, and thats just since ive started looking at your posts. Im sure you were as rude before i stared viewing too.
Also, speedstep and C1e shoul;d be on reguardless. They only affect your computer when its idle, who needs 5ghz while sitting at the desktop?
it depends computer to computer and motherboard too but I read some people with Asus boards would BSOD at idle a lot, but some BIOS updates have remedied their problem in which the offset also affects the idle voltage and not just the peak voltage.I tend to agree although a couple of people have pointed out that there are certain situations where leaving them on can cause instability so the answer seems to be leave them on unless they cause system crashes.
Yes, it is completely wrong. All that turning off EIST will do is raise your idle power consumption immensely. Ever since Core 2 EIST hasn't affected in any way the max stable overclock you'll be able to get from a CPU, and if your CPU is stable at 4GHz with EIST turned off then it'll be stable at 4GHz with it turned on.
Turn it on.
Well this is going a little OT but the mobile Core 2 were a little different, at least those that supported IDA (Intel Dynamic Acceleration) the predecessor to turbo boost.Ever since Core 2 EIST hasn't affected in any way the max stable overclock you'll be able to get from a CPU
