Discussion Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 7000, etc.)
Page 452 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Vattila
822
1,467
Except for the details about the improvements in the microarchitecture, we now know pretty well what to expect with Zen 3.
The leaked presentation by AMD Senior Manager Martin Hilgeman shows that EPYC 3 "Milan" will, as promised and expected, reuse the current platform (SP3), and the system architecture and packaging looks to be the same, with the same 9-die chiplet design and the same maximum core and thread-count (no SMT-4, contrary to rumour). The biggest change revealed so far is the enlargement of the compute complex from 4 cores to 8 cores, all sharing a larger L3 cache ("32+ MB", likely to double to 64 MB, I think).
Hilgeman's slides did also show that EPYC 4 "Genoa" is in the definition phase (or was at the time of the presentation in September, at least), and will come with a new platform (SP5), with new memory support (likely DDR5).
What else do you think we will see with Zen 4? PCI-Express 5 support? Increased core-count? 4-way SMT? New packaging (interposer, 2.5D, 3D)? Integrated memory on package (HBM)?
Vote in the poll and share your thoughts! :)
Reactions: richardllewis_01
nicalandia
3,331
5,282
AMD has the advantage of following Intel's footsteps so they end up doing things the right away due to seeing Intel's stumbling blocks. Intel however is always busy making new mistakes so they rarely go back to fix their old ones :D
That's true.
Intel HT as first implemented gave about 15% boost to MT apps. AMD SMT boosted the MT to 25% to OG Zen1
Intel MCM(Core2 Quads)<< AMD Zen1 was a better MCM and then followup with actual CCD
Intel on package L4 << AMD 3D V Cache
Intel AVX-512 While very powerful. It consumed too much power and down-clocked the CPU. AMD while not as powerful it actually performs better since the CPU is neither consuming too much power nor throttling so it's at full speed.
:cool:
nicalandia
3,331
5,282
Not sure what you are asking, but I would NEVER disable avx-512 based on what I see going on in software, I used it quite a bit of the time in DC work.
You and Phoronix have reported that the option is not even available(to disable it) from BIOS...! To the disbelief of the poster BorisTheBlade82
nicalandia
3,331
5,282
No idea, I have never looked. Just saying I would not do it.
True. it would seem that the AMD build their AVX-15 Implementation to work 100% with the core. Disabling actually hurts performance all around. Unlike Intel Implementation that actually cripples the core
Exist50
2,452
3,106
Well now you're just being silly. Even on Skylake, that was an edge case, and basically fixed with Sunny Cove onward. AMD's implementation is good in many ways, but it's not completely without tradeoffs.
Edit: Link for those interested. If 100MHz or so is "crippling", you've got a very weird definition.
alexruiz
2,836
556
That is very good, Wraith Prism RGB is coming back with R7 7700 and R9 7900.
It would be amazing if the Wraith Prism was a newer aRGB version instead of the old analog RGB one
DrMrLordX
23,230
13,314
Only on the client parts that didn't have the full implementation of something like Skylake-X. IceLake-SP is probably a different story, but I haven't seen anyone examine that. At all.
LightningZ71
2,704
3,397
IceLake mobile is binary compatible with the AVX512 functions that are supported, but, save for few cases, it isn't much faster executing avx512 than it is using AVX2 code paths for the same work.
Exist50
2,452
3,106
Exist50
2,452
3,106
If the only metric of performance is FP ops/cycle, then AVX512 does pretty much nothing for you. Maybe a little more efficient for the front end. The value of AVX512 is in all the new ops it introduced, more so than the actual vector length, and the area those benefit the most right now is AI.
eek2121
3,491
5,187
naturally this info comes the day my 7950x finally arrived :)
that said, i was not eager to wait till next september
I do wonder what the peak clocks will be. Threadripper has historically trailed Ryzen .
Really? I am honestly surprised. Most/all or only some?
There is no option currently to disable AVX-512 in the ASUS BIOS. From what I gather, none of the others have it either.
EDIT: You can’t disable AVX, AVX2, SSE, MMX, etc. either so I am not really sure how this is notable. There is no disadvantage to having it enabled, unlike on Intel chips.
Also, you can look this stuff up yourself by downloading a BIOS viewer/editor and the BIOS you want to check.
Timmah!
1,572
935
No reason for it not to clock as high as regular Ryzen on the first CCD, when only that one is utilized, IMO. When additional cores will be loaded, it can happily clock to 4,5GHz or 4 or whatever is needed to stay within the power limit.
eek2121
3,491
5,187
If Intel workstation chips hit 5.7ghz and AMD chips hit 4.5ghz, AMD is going to have a bad time. Note that I am talking single core or light multicore workloads here. Multicore workloads are going to depend on PPT. I suspect some higher end chips will have a higher overall PPT, 350W maybe? Possibly even 380W.
BorisTheBlade82
722
1,149
Yes, I must have confused this with SMT option most BIOS have. Which, by the way, I also personally never had (sadly). I switched from an original Athlon to a Phenom II X4 in 2009 and then to a Renoir 4700U which also lacks SMT.
Kaluan
517
1,100
I think some are missing the forest for the trees. Didn't we just get confirmation Thresdripper is coming back?
We knew Thresdripper Pro is (this one never left TBH), but not the prosumer kind.
HEDT is (/will be) back y'all.
Reactions: Joe NYC and Exist50
DrMrLordX
23,230
13,314
Well AMD doesn't have double FP throughput for server, so not sure what the point there is supposed to be.
The point is that Intel didn't really "fix the problem". Their approach was twofold: mostly abandon HEDT after Skylake-X, and reduce throughput on remaining client parts with AVX512. Now they've all but eliminated AVX512 except in Xeons. It's in the silicon but you can't use it.
As far as AMD's implementation of AVX512 goes, I guess it's not really so different but it's still a massive improvement for them in applicable workloads.
Timmah!
1,572
935
Let me Stop You right there... They wont. TVB Is 4.8 Ghz on Top binned CPUs.
First time i see these tables, how did i miss them, huh? Do we know the release date?
The 2495x would be interesting product perhaps, its sort of what i wanted. Do we know prices as well?
4,8GHz single core is kinda disappointing. All-core will probably be under 4GHz then. I would not be surprised if under these conditions in all-core it will beat 13900k/7950x only by rather small margin.
eek2121
3,491
5,187
I wasn’t necessary saying that Intel was going to have 5.7ghz boost. I was saying that AMD can’t afford to be conservative with clocks. Sorry if my example was taken poorly. Also it was rumored a while ago Intel might have an HEDT series under the Core branding, unsure what happened/will happen with that.
nicalandia
3,331
5,282
I fully expect no less than 5 Ghz on TR parts.
Reactions: Kaluan
biostud
20,217
7,339
I was wondering that too, with 4 memory channels.
Reactions: Kaluan
nicalandia
3,331
5,282
I am not sure if AMD would like to go that route. There was an article by Puget System about memory channel performance. 8 Memory Channels gives trample 4 channels all day long.
