Discussion Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 7000, etc.)
Page 438 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Vattila
Except for the details about the improvements in the microarchitecture, we now know pretty well what to expect with Zen 3.
The leaked presentation by AMD Senior Manager Martin Hilgeman shows that EPYC 3 "Milan" will, as promised and expected, reuse the current platform (SP3), and the system architecture and packaging looks to be the same, with the same 9-die chiplet design and the same maximum core and thread-count (no SMT-4, contrary to rumour). The biggest change revealed so far is the enlargement of the compute complex from 4 cores to 8 cores, all sharing a larger L3 cache ("32+ MB", likely to double to 64 MB, I think).
Hilgeman's slides did also show that EPYC 4 "Genoa" is in the definition phase (or was at the time of the presentation in September, at least), and will come with a new platform (SP5), with new memory support (likely DDR5).
What else do you think we will see with Zen 4? PCI-Express 5 support? Increased core-count? 4-way SMT? New packaging (interposer, 2.5D, 3D)? Integrated memory on package (HBM)?
Vote in the poll and share your thoughts! 🙂
I think because the IO die is such a large piece of silicon, AMD will be incentivized to make a cut-down version for Sienna. Their volumes are easily getting to the point where the unit cost savings will eclipse the cost of a separate tape out.
I was thinking that the best way to go about making varying sizes would be to make the IO die modular such that 2 or 4 of the same chip could be used rather than one big monolithic die. Stacked bridge chips could make that a lot better, so perhaps we will get something like that with Zen 5. They could make a cut down die for Siena. If they have a high defect rate on 6nm IO die, then just using salvage parts may make sense. Siena is supposed to be lower cost, but it is still going to be more expensive than desktop parts.
Yes, but does AMD give the chiplet and cache per chiplet counts anywhere? Just trying to figure out where the inconsistency came from. It seems like the 9124 (16-core ) and 9224 (24-core) are both 4 chiplet devices just with 16 MB of L3 per chiplet rather than 32 MB.
AMD Has never given a Chiplet per SKU information
It will not be the first time AMD cuts the Total L3$ Per CCD/Chiplet
The EPYC 7453 is a 28C/56T Zen3 CPU with 4 CCDs with 64 MiB L3$ per CPU, which means that each CCD gets 16 MiB which is half of what Zen3 is capable of.
That is the beauty - one can spin that theory both ways 😉
The question is if the amount needed will be worth the upfront costs of a separate mask set which to my knowledge is in the tens of million Dollar region. But if they sell a lot of Siena and Threadrippers it might well be worth it.
I tend to believe Sienna going to use much smaller IOD (AdoredTV has mentioned 263mm2 for Genoa which is certainly wrong but could be for Sienna platform). And Sienna platform also reduces power TDP, memory channels, PCIe 5.0 & 3.0 and CXL, so new spin seems reasonable.
And don't worry about volume, Sienna Next with Zen5c most likely coming soon.😛
That's an interesting proposal. Some overhead, but could be worth it for time to market etc. Though it does hinge on having a proportional lower PCIe lane count as well. I don't think AMD's actually disclosed that detail yet.
I was originally thinking of that since it is similar to what Apple did with their m1 max, which is essentially two APUs connected together by a silicon bridge. It would be great if AMD could do something similar, but I suspect that we may not get any stacking or bridge chips until Zen 5. If two APUs or two small IO die could be connected together, then that could have offered a very cheap way to scale the core count for higher end desktop or mobile parts.
I may not be up to date (haven’t had a lot of time recently), but I suspect that going forward, there will be a lot of overlap with GPUs and CPUs. For GPUs, I guess they are using infinity cache chips which are rumored to only be 16 or 32 MB in size. That would be a very small chiplet. I have seen some things saying that the infinity cache chiplets that go under the base die also include memory controllers. That would make a lot of sense since it decouples the memory controllers from the base die. They could use the same base die possibly across all of their products, just with different bridge chips for different memory types: GDDR, HBM, DDR. The HBM interface is actually a very small die area, so those could have larger cache in addition to acting as an embedded bridge to the HBM memory.
If you look at a block diagram of a crusher node here:
The gpu chiplet require a massive number of interconnect links. Going forward, all of those links may be put in a base die with the compute die stacked on top. So the base die would have an embedded silicon bridge to a neighboring die, possibly a number of GMI style links to connect to die that are too far away for silicon bridges, and some off package links for IO. They also need the interfaces to memory, possibly via infinity cache chiplet. Given such a base die and several different infinity cache / memory chiplets, they could stack anything on top; RDNA GPUs, cDNA GPUs, CPUs, FPGA, or other accelerators.
So, do we get any stacked chips or other exotic things with Zen 4? It seems unlikely that they would waste their time with Zen 5 probably going 2.5D and possibly 3D in near the future. I could see them possibly making a half size IO die, but that depends on how many regular IO die are not fully functional but salvageable. Given the incredible number of IO interfaces on the Genoa IO die, it wouldn’t surprise me if a lot of them are defective in some way. Bergamo likely just uses the same IO die as Genoa. It is a little disappointing that we are unlikely to see any stacking with Zen 4. We will see it in GPUs first, but that makes sense since GPUs need so much more bandwidth.
We already knew the Genoa die sizes a long time ago from the gigabyte leak (copied from hardwaretimes; first Google hit):
“The documents also contain information regarding Zen 4 die sizes, such as the CCD and IOD. As per the leaked data, the Zen 4 CCD will have a die size of 10.70 x 6.75mm (area:72.225mm2), while the IOD will be 24.79 x 16.0mm (area: 396.64mm2).”
That is very large, but given the number of interfaces, it seems likely that they would have a lot of defective but salvageable parts. Given the incredible performance of Genoa, they will be making a lot of them.
I think that's an easy bet. I don't have data for N6 mask or wafer prices, but let's just assume Siena's IO die is half Genoa's. That's ~200mm2 of silicon. Order of magnitude, that's somewhere in the 10s of dollars range. Means they'd only need to ship O(millions) of units for it to make sense. Siena should easily be able to hit those numbers.
Ok, 230$ is much beeter price as the cheapest CPU entry in AM5.
Especially if they launch A620 mobos around that time as well.
IMHO, such prices (if at least somewhat accurate) also leave some room for a bit of X SKU price readjustment. Raphael-X needs that room too.
Speaking of the only X3D SKU we know for certain we'll see, the 8 core, I don't see 7700 at $330 and 7700/7800 X3D at $450 not completely destroying $400 7700X sales.
Loosing a little is better than inventory sitting around. I just got my 3rd 7950x for $100 less than the first 2.
Which won't be a thing on next restock anyway. Since AMD will sell them for less than the launch batch(es). At least I assume that will be the case.
Resellers, big or small, have seen worse, much worse. Especially from other chip giants. I wouldn't worry too much for AMD's client channels.
Edit: Or was this about AMD's margins? Why is that even a topic? lol
Are we just gonna pretend the economy is fine? Or that Intel isn't taking even more brutal cuts to their margins selling 25% bigger dies for almost the same price as the ones from one year ago, right out of the gate. Just weeks after industry sources said they will increase prices by 10-20%? 😂
None of you lot are buying from AMD but retailers. Remember this.
All firms client margins will be hit. Those with the best cost structures will be the winners. Which ones are they, do you think?
obviously Intel with cheap insider silicon and simple monolithic packaging. Raptor is a big chungus die though. AMD also clearly said they rather stop shipping to reduce channel inventory than compete on price.
Why do you think running your own fab with all the R&D costs included is always cheaper that outsourcing to a specialist? That is such a misguided belief I see repeated contiguously.
Well maybe all the firms just abandon client. Joking of course, but they will have to drop prices as we see happening. With major companies firing workers & consumers revaluing wants, the TAM is falling. That's a fact that cannot be dismissed.
Do we still don't understand what's happening?
