Discussion Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 7000, etc.)
Page 355 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Vattila
822
1,467
Except for the details about the improvements in the microarchitecture, we now know pretty well what to expect with Zen 3.
The leaked presentation by AMD Senior Manager Martin Hilgeman shows that EPYC 3 "Milan" will, as promised and expected, reuse the current platform (SP3), and the system architecture and packaging looks to be the same, with the same 9-die chiplet design and the same maximum core and thread-count (no SMT-4, contrary to rumour). The biggest change revealed so far is the enlargement of the compute complex from 4 cores to 8 cores, all sharing a larger L3 cache ("32+ MB", likely to double to 64 MB, I think).
Hilgeman's slides did also show that EPYC 4 "Genoa" is in the definition phase (or was at the time of the presentation in September, at least), and will come with a new platform (SP5), with new memory support (likely DDR5).
What else do you think we will see with Zen 4? PCI-Express 5 support? Increased core-count? 4-way SMT? New packaging (interposer, 2.5D, 3D)? Integrated memory on package (HBM)?
Vote in the poll and share your thoughts! :)
Reactions: richardllewis_01
Rigg
718
1,822
Markfw
May 16, 2002
27,418
16,277
Might not be anything official from AMD and retailers tend to discount older generation parts before a launch, but it doesn't matter what the reason is if you can get a cheaper part.
Zen 3 is still a great CPU and even though AM4 is EOL if the price is cheap enough, it can make a great system.
Didn't you read ? AM4 is NOT EOL. It will continue as (most likely) the value line. For how long I don't know, but Lisa said so.
Saylick
4,154
9,695
If true this is huge
Yet another half-assed, two-bit article from Hassan from WCCFTech... I was trying to figure out in the article which store offered the prices listed in the heading and there wasn't an obvious link or anything, then I see this:
I figure it's MC pricing that gets that low, which if it is the case is kind of disingenuous since not everyone has access to MC.
Mopetar
8,534
7,799
We're probably mincing words, but it's not getting any new products so it's a dead end going forward as far as upgrade options. That doesn't make it useless and it'll still get some support and updates (so if you want to use EOL in that way you're absolutely correct) and with price cuts is probably better value for dollar than a new Zen 4 build. But you pay a price for buying into AM4 now and that's having no path forward excepting plugging in a better Zen 3 CPU to get more cores.
Reactions: scineram
Markfw
May 16, 2002
27,418
16,277
I would guess that is will be competing price wise and performance wise with the 13001 or whatever the bottom few Raptor lake are.
Reactions: Drazick
Kaluan
517
1,100
By that kind of silly reasoning, Socket 1700 will go EOL in exactly 4 months on the dot, if ADL launch was any indication. How 'bout that as a "no path forward" for a so called next-gen product people are supposed to be excited about?
EOL literally means something is either not produced anymore and/or not maintained or supported anymore. None of that applies here, so maybe let's not change the meanings of words for giggles, there's already enough of that going around everywhere else.
And at any rate, I'd like a peek into that factual inside info source you have/crystal ball. Cause there's literally no way anyone can say for sure there's no new SKUs being launched for that socket.
Borealis7
2,901
205
The MT ratio is shockingly high. 21.55!
for comparison 5950x ALL cores OC 5.1Ghz only has 19.86 MT ratio:
stock 17.58
MT ratio seems like a very irrelevant and made-up metric, notice that neither Intel nor AMD use or cite it as a metric for anything.
the reason is the MT ratio just scales with the number of threads, each thread's frequency, the IPC of the architecture and most of all it is very workload dependent (the level of parallelism of the task you are performing). a CPU can have a MT ratio of 20 in one task and 15 in another...
you could compare the same task performed across many CPUs and measure the MT ratio, but the result would be not be a measure of efficiency unless you are comparing CPUs with the same number of threads and at the same frequency PER THREAD (or logical core). looking at the end result, and measuring performance/Watt is the industry standard and basically the only thing that matters because that translates directly into money.
I am just a humble B.Sc CompSci, but that is my view on the subject.
19,219
19,219
Still, it's amazing that a top-of-the-line chip is easily available for that much. I don't see anyone selling me a 12900KS for that amount.
inf64
3,884
4,692
Well, soon the 7950X will make the 5950X a mainstream desktop part, no wonder we have price cuts :D. ~30% higher ST and ~45% higher MT performance is a huge uplift. Still, the 5950X will remain a formidable force, especially for people on AM4 who do a lot of content creation and gaming.
Kaluan
517
1,100
Yeah, that price ~$500 for the 5950x, isn't that amazing. It's been weeks that you could find them there. The 5900x has also been going for sub $350 for weeks now as my son took advantage of to upgrade his 2700x to a 5900x for $339 over two weeks ago.
5950X @$500 would actually be worse value than 7950X @MSRP in certain ways heh
Judging by the slides/footnotes, I think some are overestimating how big the performance gain from EXPO will be, I think most will be fine with some 5200CL38. It was compared vs JEDEC 4800 after all, more or less the worst case scenario, under-spec and all.
Mopetar
8,534
7,799
Definitely will have to since AM5/Zen 4 won't have anything comparable for months since AMD isn't launching the bottom half of the product stack until later.
Considering DDR5 is still a bit pricey it doesn't make a lot of sense for AMD to sell budget CPUs yet. Who would want to pay more for their board and RAM than the CPU they're going to pair with it?
That's probably a better way of defining it. I would say that Intel doesn't have any newer replacement options for socket 1700 either now or in the near future and even after the RL launch, there's still a good chance that additional CPU models will be released.
My only complaint is that "No Path Forward" just doesn't sound good to my ears. Maybe "Dead End" is a bit more fitting. It suggests that it's not going anywhere, but that hasn't necessarily reached that end yet.
jamescox
644
1,105
It seems like that is true of just about everything though. I think the term IPC is massively misused. It varies massively between applications and can vary significantly between different components of the same application. It can also vary significantly with input data. That is why you should look at data for the applications you actually run.
Reactions: Tlh97 and Kaluan
Timmah!
1,572
935
Nah, its still only 16C chip in age, where 96C ones exist. There is really nothing top-of-the-line about it, except being top chip into AM4 socket.
biostud
20,238
7,363
Exactly, and why AMD used an average of 22 applications to give an average IPC lift of 13%.
