Speculation: Ryzen 4000 series/Zen 3
Page 148 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Thunder 57
4,244
7,039
New information on the Vermeer engineering sample has been published by Igor'sLAB
Translation by VideoCardz
The new information is for the clock speeds, which were decoded from an OPN code Igor was given by the source:
100-000000059-52_ 48/35 _ Y
The 48 stands for 4.8 GHz boost clock, while 35 means 3.5 GHz base clock. It is worth noting that this is still not the final sample, but definitely a faster stepping from the previous report. In June Igor covered first data on the B0 samples which were featuring a boost clock of 4.6 GHz and a base clock of 3.7 GHz.
100-000000059-14_46/37_Y
100-000000059-15_46/37_N
AMD Vermeer to feature Per core voltage adjustment
Intel recently introduced a new feature with the 10th Gen Core series. This feature allowed per-core voltage adjustment for increased optimization and overclocking. This feature is also coming to AMD platform, as the changelog for the ComboAM4v2PI 1.0.6.0 (or 1006) reveals:
Very interesting. I'm sure AMD would to get to that magical 5GHz number. But maybe we won't see that until AM5 with DDR5, PCIe 5, Ryzen 5000 series, baked in 5nm, and launching on 5/5 naturally.
Kenmitch
8,505
2,250
Last I checked Walmart doesn't make anything. They dictate cost and pricing from their vendors. What is your point? The term rollback pricing is something AMD should consider.
....And you ask what's my point?
Maybe you should voice your opinion towards those whom make the motherboards. AMD has no control of the end price of a motherboard.
Asterox
1,061
1,876
4.8ghz Singlecore boost is expected.5ghz mantra is blah, "only Intel needs 5ghz to stay relevant in 1080p gaming on 1200$ GPU".
Weird people with 1200$ GPU slap games in 4K, well it could be much worse. :relieved:
Thunder 57
4,244
7,039
So they'll launch at 5:55AM or PM?
That's where the run out of luck. Because the best they could do would be 05:55. Though maybe they combine the 5th day with the 0 in 05:55 to make 50, and say it's AMD's 50th anniversary. Except that was last year :confused:.
I know that, we probably all do. But at least AMD could bring back that 5GHz tachometer/speedometer video and leave the 5 in it. Great for marketing. Don't forget when it comes to numbers people are stupid. $99? That sounds way better and cheaper than $100! What a deal!
Ajay
16,094
8,114
4.8 GHz boost sounds nice, if true. The point that matters most to me is typical boost, as opposed to peak boost. But, yeah, marketing...
Asterox
1,061
1,876
It is no doubt for one Core. All Core Boost will be hm, around 4.2-4.3ghz no higher for 16/32 CPU.What else do you need, 8 Core CCX+other CPU enhancements or again 15% higher IPC.
Ajay
16,094
8,114
I won't be upgrading, the improvements won't be enough for me to bother (and I'd rather use the same system, sans GPU, for ~5 years to get some value out of it).
If AMD does pull off around 15% higher performance per clock, that would pretty clearly end any claim to Intel ST performance superiority.
Reactions: trollspotter
Makaveli
5,004
1,603
If the Zen 3 shows a nice boost paired with a IF of 2000 paired with DDR4000 I would consider it. However I'm only on 8 cores at the moment and would just upgrade my HTPC to the 3800X or sell it. This is also one of the reason's I'm staying at 16GB and not going to 32GB incase I need to buy new memory.
Priority for me right now is GPU upgrade though to RDNA 2 is on the list before cpu upgrade.
Asterox
1,061
1,876
This will most likely be a top model 16/32 Zen 3 CPU.
Expected price hm, around 800$ for 4.9ghz Singlecore Turbocore boost.
Makaveli
5,004
1,603
What was the Launch price for the 3950X around $750 no?
So that price seem reasonable for a part that offers the same core count but is faster.
Kenmitch
8,505
2,250
Yep $750 on another note it's currently $670 at MicroCenter
I'm more interested to see how the memory clocks turn out. It would be nice to run my b-die closer to it's true potential without sacrificing latency.
....Waits for reviews or at least some juicy leaks.
Reactions: Tlh97 and Makaveli
Gideon
2,043
5,097
These clocks were a nice surprise, i did not expect it to reach 4.9. This might make it really tempting for marketing to do a 5.0GHz Black Edition or something similar.
The added move instructions will help as well, can't wait to see some leaks.
soresu
4,234
3,736
It will be interesting to see what happens to pricing and SKU core counts per segment when the next big shrink comes with Zen 4 and we get another doubling of cores per socket.
I hope 32 cores comes down by at least 1/3, I could live with that and would definitely go for it at £1300-1350.
Ajay
16,094
8,114
Doubt that will happen with Intel sucking so badly.
soresu
4,234
3,736
Depends how fast they get 10nm more production capable and scale up the core count again, right now they are chugging electrons faster than a Bugati does gas to keep relatively 'even' with AMD on core count.
Markfw
May 16, 2002
27,378
16,221
server, 28 vs 64 is relatively even ? Or desptop, 10 is relatively even with 16 ? HEDT, 18 vs 64 ? Where does Intel come close ?
inf64
3,884
4,692
If Alder Lake matches Zen 3 16C in ST and MT performance it will be a miracle. I'm not even thinking about Zen4 which will be more like Zen1->Zen2 jump, with 2x the core count and FP throughput (Vs Zen3). It will be brutal 2-3 years for intel.
Ajay
16,094
8,114
Uh, yeah, when were 10nm Intel products due for release - 2016/2017. Not certain, but, after several years they have only 3 fabs running 10nm. Performance and yields have improved a fair bit for small dice (quad core CPUs). But, for large dice like ICL-SP (supposedly up to 38 cores - which we haven't even seen leaks of yet); seems like Intel will be producing those at a loss for some big customer who needs certain features found in the Ice Lake ISA.
amrnuke
1,181
1,772
While this is not the thread for Zen4, I have to ask... is Zen4 confirmed to go up to 32 cores / 64 threads on Ryzen line? And 128 cores / 256 threads on the TR side? And 256 cores / 512 threads on EPYC?
Ajay
16,094
8,114
Not that I've heard. And if I heard that right now, I would be very skeptical that it was anything more than a guess.
Reactions: scannall
soresu
4,234
3,736
Eh?
I thought that they had 56 core SKU's?
That's what I meant by relatively even, and even then only in absolute single thread or MT + AVX 512.
I'm not amping up Intel here, actually the opposite - I was meaning that when 10nm matures further that they will scale up beyond 56 to better compete, even if the TDP goes thru the (already burning) roof in the process.
