Speculation: Ryzen 4000 series/Zen 3
Saylick
4,125
9,642
There was 1.5 year between "design complete" and release of zen2.
Design Zen3 is complete now, so Zen3 in Q1 2021 ?
(Based on intels speed/delays they could actually do that)
Although Zen3 comes probably sooner like end 2020, Zen2 was a big change on all design levels.
Agreed, I'm thinking Zen 3 comes out Q3 2020. Zen 2 involved transitioning to a new node along with moving to a chiplet-based design while Zen 3 will build upon Zen 2 more so than establish a new design paradigm, so AMD should be able to bring it to market quicker than it took them to bring out Zen 2.
scannall
1,960
1,678
At some point they will finally be free of the WSA with Global Foundries. Maybe Zen 4? The I/O die on 7nm or 5 nm will be a nice step forward as well.
Thala
1,355
653
You're repeating a common opinion that if Apple (or anyone really) wanted to, they could scale up an ARM design and it would destroy everything. It's not that simple. Others can surely explain it better than I, but you can't just say that because it runs at x GHz and q voltage, it can run at y GHz at p voltage. So many different things affect frequency.
First of all i am not expressing my opinion but just physics. The fact that higher voltages leading to higher currents leading to higher frequencies is affecting every digital circuit in a very similar way within the same process technology. It does not matter if this circuit is from company A or B. If i have a circuit which can be clocked 2.5GHz@0.75V, then it can be clocked around 4GHz+@1.3V - its not too hard to grasp the concept.
Thunder 57
4,294
7,100
That's nonsense. You are still limited to the frequency of your slowest pipeline stage, for one. Otherwise why couldn't P3 Tualatin clock as high as P4 Northwood?
Reactions: Tlh97 and NTMBK
Thala
1,355
653
*sigh* ....
And you slowest pipeline stage also limits your frequency @0.75V - its just that you slowes pipelines stage also gets faster @1.3V - thats the whole point! Hope you start to understand now...
And why does P3 and P4 play a role here? They are not remotely part of my argument. Not sure why you bringing up totally unrelated questions?
Thunder 57
4,294
7,100
*sigh* ....
I think you started to reply before my edit. I realized that as soon as I posted it and went to add an example. Shouldn't have posted that quickly. The point is that architecture matters as well. They both came off the same process and ran at similar voltages, but clocked very differently.
Thala
1,355
653
Of course the architecture matters, but thats not my argument at all. My argument is, that if 2 circuits reaching roughly the same frequency at lower voltage, they will also reach roughly the same frequency at higher voltage - because the frequency - voltage curve is similar.
Your P3 vs. P4 question is unrelated because P4 reaches higher frequency at both low and high voltages - so the do not have the same frequency - voltage curve. Why is that - because P4 most likely have shorter critical logic pathes between 2 registers than P3.
Thunder 57
4,294
7,100
Fine, then let's compare Tualatin to Thoroughbred. Again similar voltages. P3 topped out at 1.4GHz, Athlon XP hit 1.8GHz. It was revised and hit 2.25GHz. Of course now we are talking about different fabs, but both had excellent 130nm processes at the time.
Thala
1,355
653
Fine, then let's compare Tualatin to Thoroughbred. Again similar voltages. P3 topped out at 1.4GHz, Athlon XP hit 2.25GHz. Of course now we are talking about different fabs, but both had excellent 130nm processes at the time.
I am talking about 2 architectures reaching the same frequency at the same voltage at iso process, you are bringing up examples where 2 architectures hit different frequencies at the same voltage.
I never claimed that any 2 architectures can hit the same frequency - only when they hit the same frequency at a reference voltage point.
Thunder 57
4,294
7,100
Understood, and you are right, I wasn't making the correct argument. The problem is that trying to find a comparison is like trying to find a unicorn. CPU's are all designed with different characteristics in mind. My next guess would be to go to look at Core 2 Duo vs Athlon 64 X2. Pretty sure there would be a comparison there with comparable voltages but the A64 would clock higher but still get beat in benchmarks.
I guess the best way to put it is that CPU's are designed for specific purposes. I don't believe A12 could scale up and best x86 just the way Atom couldn't scale down and beat it at the same power. Until we see something more than low power ARM chips I don't think anyone will know for sure. I am just of the belief that if it were that advantageous, it would have been done before. I'm sure we will see attempts in the future, but at the moment we just don't know.
Thala
1,355
653
The done-before argument is not really valid in this case, because you design SoCs for a certain purpose. If the purpose is to put it in a Phone, you would never even remotely consider 1.3V Vcc - in fact you power supply unit would not even support these voltages and required currents.
But as you can read in the article linked by Naukkis if you give the Cortex A72 enough voltage you will pass 4GHz. You dont have to make a chip though, you just need to sign-off the timing (with EDA tools like PrimeTime). In what product would you put a 4GHz Cortex A72 anyway? Remember power goes up by a factor of 4 roughly. (1.2/0.75)^2*(4/2.5) = 4)
Cortex A72 frequency-voltage curve
Reactions: guachi
Thunder 57
4,294
7,100
Well I seemingly wrongly assumed you were one of those "ARM will take over the world" guys. About 10 years ago even Anand was talking about x86 in iphones. Clearly that never happened. Meanwhile we have had people talking about ARM taking over x86, and that has yet to happen. There was a similar RISC vs CISC debate in the 90's, and we all know how that turned out.
If after 10+ years we haven't seen x86 on mobile or ARM on PC's, I have to think they are both the best at what they do in those form factors. Maybe we will see an ARM uprising within five years, maybe not. I would bet against it though. Sorry if I misunderstood you as an "ARM everywhere" type.
DrMrLordX
23,225
13,304
Let's not forget the GloFo issues.
True. That was one of the reasons why Rome was shipping (to select partners) so long ago while Matisse was delayed, I imagine. Matisse was originally supposed to be on GF 7nm while Rome was always slated for TSMC.
AMD wisely didn't commit to them by the looks they were able to switch to TSMC. That could have bit them hard but I think it only cost them 1-2 months. Who really knows, though? I expect to see Zen 3 in late August at best to mid October at worst.
July/August seems rational. A lot of it depends on whether TSMC continues to deliver on their nodes in a timely fashion . . . assuming Zen3 is on 7nm+ EUV.
Kenmitch
8,505
2,250
What do you think Skylake or Zen2 can be clocked @0.75V?
Zero, zilch, nothing!
Maybe it's my MB's uEFI or just the way it is. I've run my 3700x all core underclocked to 3.2 GHz @ 0.850v's for some testing without any issues.
Using Ryzen Master selecting anything under 0.800v's it's a instant reboot once applied. Entering bios and doing the vcore over ride option nothing below 0.800v's is available.
Was this a trick question?
maddie
5,204
5,614
Some implied assumptions here.
If the CPU core chiplet is identical on both processes, TSMC 7 & GloFlo 7, then there should not be any delay by using one fab or the other. Are you assuming there were some slight differences between the chiplets from each fab, maybe power/frequency curves, to fully utilize the unique properties effectively? Might the lower than expected clocks on Matisse be caused by this?
If above is close to true, Zen3, AFAIK, was never meant to be fabbed at GloFlo so we might see a bigger increase (IPC + frequency) than expected as all the variants were designed for 7nm+.
Paul98
3,732
199
I expect something like a 5-10% bump in performance per clock from architecture changes, a 10% increase in performance from 7nm+, and better overall chip binning, and a top end 16 core chip at 499.
Tuna-Fish
1,694
2,601
The design rules and cell libraries are entirely different between TSMC and GloFo 7nm. The entire low-level design and debugging phase needs to be redone. That's about 12-18 months of work, assuming sufficient workforce.
Note that I don't believe that anything Zen2 was ever designed for anything GloFo. People assume that major decisions were done when we heard about them or at least not too much before them. I don't think either AMD or GloFo would have winged it, the major decisions were probably made years ago, and Zen2 was always going to be TSMC.
Reactions: lightmanek
Richie Rich
470
230
That's perfect post regarding power consumption. Thanks for that.
Some people has difficulty with understanding the difference between P3 and P4 pipeline and so affecting frequencies (f/V curve). Me as mechanical engineer I have to use always electric->hydraulic analogy. This helps me to understand and imagine the electric processes inside (voltage is pressure, current is mass flow etc).
Those people should imagine this:
  • - every stage of pipeline ......................... . as water channels complex
  • - transistor switching every clock ......... as tsunami wave running in those channels
  • - electron/transistor speed is constant ........ as tsunami wave speed is constant too
  • - critical path ............................................. as the longest possible combination of channels to get to the end of stage (tsunami wave with the longest time to complete) - basicly this limits your frequency because you cannot run next clock/wave before last tsunami is finished. If you do, for example during OC, you get faulty results from logic and your PC crashes. That's why OCed CPU is stable at desktop (not using critical path) and not stable when you run heavy FPU AVX load (using critical path). I think this is the problem of Intel AVX512 down clocking too.
So from above we get:
  • - P4 high frequency architecture has shorter/less complex channels... able to run more tsunamis at time (more freq)
  • - P3 low frequency arch has longer and complex channels... able to run less tsunamis at time
  • - all stages in pipeline should be as eqal as possible in terms of critical paths. This is needed for good power consumption and frequency scaling.
Beside this, to reach higher frequencies you have to adapt memory subsystem too. Typically to keep feeding high freq core you need bigger buffers for uncore because RAM latency is constant.
You can see that ARM cores performance doesn't scale as good as Skylake - due to their design. Apple desktop ARM CPU will need some modifications for high frequency for sure. However those changes are not major IMHO. Apple's 6xALUs design is their key advantage and huge milestone. High freq modification is easy IMHO.
ARM is not taking over x86 desktop because Cortex CPUs are very weak and useless. This will change when powerful ARM CPUs are delivered. Cortex A77 (4xALU) core is comming this year... this might fight with Intel Atom pretty well -> take over whole NAS markets and low cost laptops.
DrMrLordX
23,225
13,304
Exactly.
I'm not so sure about that. Matisse and Rome share a nearly-identical chiplet design. When GF canned their 7nm, AMD could have just cancelled the GF Matisse design effort and moved Rome chiplets into the Matisse package.
NostaSeronx
3,815
1,294
AMD never had any GF 7LP products besides that one APU that's now on TSMC anyway.
It would be more accurate to say there was no 7LP products. AMD and IBM was apathetic about the 7nm node and NextGen(3nm GAA) at GlobalFoundries.
IBM said they wouldn't give them the product ramp they want.
AMD said they wouldn't satisfy the capacity split (<70% TSMC/>30% GlobalFoundries) in the long run.
March to May 2018 --^
Especially, since GloFo 3.0 is all about switching to FDSOI.
45nm FDSOI RFE/SPCLO
22FDX
12FDX
Reactions: Tlh97 and Tup3x
Tuna-Fish
1,694
2,601
Matisse and Rome use the same chiplets. I see no reason whatsoever to believe that they ever would have used different chiplets. It's an insane proposition, much of the value of the chiplet design is getting to use the same cpu chiplet (with super-expensive masks) with many different IO chiplets (with much cheaper masks) to make multiple different products. Matisse was always going to use the same chiplet as Epyc and TR. That chiplet was designed from the start to be on the TSMC 7nm.
"Matisse was supposed to be at GloFo" is just one of those completely unfounded false rumors, that people are trying to fit to data way too hard. It's not true, it was never based in any truth, there never was any reason to believe it was true.
Much like the AdoredTV specs leak, there are still people on this forum claiming it's inaccuracies were just changes made before release. The person who fabricated it and posted it on reddit admitted to inventing it. Yes, it got some things pretty close, but that's just because it was the best effort by a fan to guess what's going to be.
Reactions: Tlh97 and misuspita
Veradun
564
780
Didn't they say they started dual sourcing 7nm products and at some point dropped the ones on GF for obvious reasons?
DrMrLordX
23,225
13,304
Pretty sure they did. Rome and Vega20 were confirmed TSMC 7nm, so the expectation was that AMD was going to use GF for everything else. Nothing else was officially confirmed of course. And as time wore on obviously everything was moved to TSMC.
