Soup recommendation for hoity toity dinner party
linuxboy
You can go from a bag of onions to bubbling cheese on top of dark brown onion-y goodness in under 2 hours.
How can you achieve good flavor with only 30 mins of everything cooking? Plus what about the layer building with wine, sherry, and broth? Can't add them all at the same time, the balance will be off without layered additions. Mine takes 4-6 hours total, and I usually make ahead, and finish the following day, letting the flavors meld together.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Just when you think you know a guy ... don't tell me you have an apron with your name on it too ??
o_O
No, I just wear my AT 'Cheesecake is PIE' shirt when I cook. Inspiration yo.
KT
Fritzo
41,920
2,161
Huh? I just caramelized some onions, it took ~20 minutes and it smelled great.
You're probably thinking of sauteing onions. You have to cook onions until they're nearly crystallized for french onion soup. The darker the better. If you heat them too fast they'll burn in some parts and be undercooked in others.
The reason french onion soup is expensive in restaurants is it takes a long time to make. It isn't just "fry up onions and poof!"
Howard
47,982
11
linuxboy
Howard, it's just not the same raising the pH. Sous vide method is brilliant, however. Sweat, cook off liquid quickly, and then finish in sous vide to desired level. Have never tried pressure cook approach.
Howard
47,982
11
Yes, I agree. Baking soda makes the sweetness taste strange to me. Still, beats sweating for half an hour or more.
16,852
59
86
If you want to make a great French onion soup try this method:
http://www.food.com/recipe/french-onion-soup-the-cooks-illustrated-way-344164
It is labor intensive and requires an investment of time but the results are beyond compare. One of the few foodie things I am a complete and total snob about is French onion soup and this one is the best by a long shot.
If you do try this recipe do not forget to slice the onions as directed - from pole to pole - i.e. - from the root end to the top; otherwise the onions will have a mealy mouth-feel.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Here's a recipe for Brazilian black bean stew that's very tasty and unusual with mango. You can never go wrong with using whatever fresh vegetables are in season and available like Asparagus to make soup. As a Chef, I can tell you there is no such thing as a soup being more "hoity toity" than another. It's all about preparation and presentation. Go ahead and serve "Chicken and Stars" but, make your own chicken stock and pasta to cut stars out of.
disappoint
10,132
382
Lot of suggestions for Vichyssoise. If I'm not mistaken isn't that a cold soup? I'd serve a hot soup in the wintertime and reserve the cold soups for summer. Though Vichy can be served hot it's traditionally a cold soup.
I still vote for Lentil soup.
KMFJD
33,375
53,366
So damn good
- Cut up a roast into small pieces of meat and cook
- cut 2 large onions and cook
- cut 2 large carrots and cook
- 2 green and 2 red peppers, cut and fry
- add 3 liters of water and 1/2 tin of tomato paste
- season with salt/pepper/ garlic powder / hungarian paprika / oxtail soup mix/ caraway seeds / 4 beef bouillon blocks
- bring to a boil and then let simmer for 2-3 hours
- cut up 5-6 potatoes and add it to soup, let simmer for another 45 minutes, season to taste
