Ctrl-Alt-Tilde combo - in there type "timedemo demo1.demo" (without the quotes)Originally posted by: CraigRT
what the hell.. how does one open the console? tilde doesn't seem to work.. no mention of how in the game controls.. this is a bit odd.....![]()
My system P4-2.4C @ 3.2Ghz / 1GB Geil DDR3500 / 9800Pro (405/390) / CAT 4.7 does about 45 FPS @ High 1024x768. Just changed the cache from 20 to 128. Will benchmark and post the results.
Before tweak: 44.8
After tweak: 44.8
No benefit whatsoever here. Now how do we enable triple buffering?
If enabling triple buffering means setting the "Z Buffer Depth" to 24 then I did it and reran the benchmark
Z Buffer @ Default: 44.8
Z Buffer @ 24 bit: 45.0
Z Buffer @ 24 w/Vsynch on: 41.6
Thanks DarkKnight... Will try that tomorrow. Just got done playing a couple more hours. Now I've got to try and go to bed.Originally posted by: DarkKnight
go to the ati control panel, opengl, compatibility, enable triple buffering.
AFAIK 24 bit z-buffering allows more precise HSR (hidden surface removal), which could mean, less part of an object (or moreWhat exactly does 24-bit Z buffering do? Does it compromise graphics quality? Enabling triple buffering gave me a nice bump of about 5-7 FPS, but the cachemegs tweak has shown no benefit for me.
Originally posted by: nitromullet
Has anyone bothered to try out different AGP aperture sizes. I have neither Doom3 or an ATi card, so I can't do it, but I'm curious. It just makes sense to me that if your AGP aperture is smaller than what you have set as the cachemegs value, the change would have no effect.
Originally posted by: Lonyo
Originally posted by: Somniferum
When you say "cachemegs", which setting are you changing exactly? I assume this is a line in the DoomConfig.cfg file that you are editing -- what's the exact name of the setting so I can try this myself tonight?
Thanks in advance!
Doomconfig.cfg file:
seta image_cacheMegs "xx" (Default 20)
To change cachemegs setting.
The xx is 20 usually, I have mine at 256 currently.
Haven't tried any higher yet though, not sure if I'm going to bother either.
The cachemegs tweak was proven to have no impact on performance. Altering those settings can make Doom3 fail to load and can produce image anomalies.
I have my AGP aperture at 256mb, but I've been doing that since Far Cry and the ATi Ruby demo. Any lower and I get worse performance.
I'm running a R9700PRO 128mb.
