Solution for being between belt holes?
krylon
3,927
4
Until you can loose a little more weight and move down a notch comfortably, fold your penis upward so it is between your waist and the belt. This should take up the extra slack you are currently experiencing.
-KeithP
That is called a Texas Tuck
Sep 7, 2009
12,960
WTF are you talking about? You think those holes weren't originally punched in the belt? JC man, learn how to solve a damn problem for once. This can't get any easier.
I'm sorta OCD about some things, and having an obvious extra hole would bother me.
I ended up buying a wider belt which sags less. Still annoyed.
And ROFL and the woven belt lol
Sep 7, 2009
12,960
Why? The belt looks the same and it still works.
It doesn't ever look the same. For one, the leather isn't dyed in the hole, which is obvious if you have to move up/down a notch. Basically, as long as you're using the makeshift hole then no big deal, but it does ruin the belt.
Obviously this is a matter of opinion - and in my opinion punching a hole ruins the belt. :)
aleckz
1,032
Well, I would buy a new belt that doesn't have holes in it. Then you can buy a hole puncher and punch the holes yourself so that they fit you perfectly.
0roo0roo
64,795
84
nail + hammer.
...where do you think those holes came from? Is there some rule preventing you from altering your own clothes as you see fit?
in my experience it doesn't result in a clean hole because drilling soft leather sorta twists and shreds instead of coming through clean.
i think the holes need to be punched through with a hollow rod tool, a nail doesn't work right either.
feralkid
16,831
4,934
Leather punch.
Works great for making gaskets as well. I know...real old school.
Possessed Freak
6,045
How expensive is this belt that you don't want to modify. Either live with it being too tight or too baggy or add a damn hole.
Pepsei
12,895
wow. i guess you can
1. use proper tool to make another hole
2. gain/loose weight
3. buy another belt
4. walk around holding your pants up with a semi useless belt.
5. ....
am i missing anything else?
drum
6,810
4
I've been using the same belt for 12 years. only had to punch one hole in it because I needed the belt to be smaller than the smallest setting
oddyager
3,398
Lose weight, buy another belt, or use suspenders.
Unless the new mod is at the very end I would NOT punch another hole in between existing ones.
FoBoT
63,084
15
fobot.com
Eat bigger hamburgers or eat smaller hamburgers
fixed
zinfamous
111,695
31,043
my opinion is that you are a cheap ass, unwilling to admit that the only solution to your problem is to buy another belt as you seem to have a delusional attachment to a valueless piece of leather.
SlitheryDee
17,252
19
Shorten the belt slightly from the buckle end. It's easy to do if you have pliers, a hole punch, and some replacement snaps or brads. It doesn't have to be neat either since the overlap at the other end of the belt will cover your handiwork when the belt is fastened around your waist.
