Solution for being between belt holes?
Sep 7, 2009
12,960
Man this is annoying.. I'm almost to the point of being able to go down a notch but not quite (my pants want to get bunched up) but if I let it out one hole then the front of my belt sags.
Is there a solution?
Edit:
Punching another is means ruining the belt. It's extremely obvious once you go up/down another size. I think I'm going to try safety pinning the front so it doesn't sag
FoBoT
63,084
15
fobot.com
no really, wear suspenders
NSFW
http://www.pics.bbzzdd.com/search.php?q=suspenNSFW
zinfamous
111,695
31,043
nail + hammer.
...where do you think those holes came from? Is there some rule preventing you from altering your own clothes as you see fit?
KeithP
5,664
201
Until you can loose a little more weight and move down a notch comfortably, fold your penis upward so it is between your waist and the belt. This should take up the extra slack you are currently experiencing.
-KeithP
seepy83
2,132
Assuming that your belth is leather, the proper tool would be a Leather Punch.
Nov 7, 2000
16,403
make a new hole
wear a different belt
lose weight
gain weight
suspenders
i think that covers all your options
Ausm
14
-KeithP
lmfao
ktehmok
4,326
-KeithP
ROFL, Brilliant!
Seriously, it's only a belt. Are you worried about the resale value on it? Punch another hole & be comfortable.
zinfamous
111,695
31,043
woven belts do not have holes... problem solved.
A woven belt is like a beacon that informs the rest of the room that a Dork is present--do not engage lest you be taken down with comments about Capt. Kirk and Ms. PacMan.
zinfamous
111,695
31,043
Edit:
WTF are you talking about? You think those holes weren't originally punched in the belt? JC man, learn how to solve a damn problem for once. This can't get any easier.
