Originally posted by: ribbon13
Originally posted by: Tick
Originally posted by: Tsuwamono
Wow, sorry mate... you should really change your name then lol he pisses off alot of people on the TechGFX board and a few others. people might mistake you for him like i did and make an ass of themselves.
Umm, you can't change your name without a new account, and you aren't allowed to have 2 accounts.
Um, no that's not true at all, all you have to do is PM AnandTech Moderator and ask politely.
This would be the configuration of the 940 rig:
Supermicro H8DCE mobo
2x Opteron 270
4x 1GB REG ECC RAM, haven't decided exactly what sticks
8 port SATA RAID controller, PCI-e, haven't decided brand
4x 250 GB HDD from current rig
7800 GT from current rig
Audigy 2 ZS Gamer from current rig
Haven't decided on PSU yet, but it needs to give >700w and be SSI compatible with a 24 pin, 8 pin and 4 pin mobo connector, and the PC P&C one is just too overpriced
Powercool PCI-e TV tuner card, to replace current one, because Haupauge doesn't want to support 64-bit
DVD burner from current rig
Yeah, ok.... I'll be using it for photochop (GIMP actually), some video editing, some 3d work, Gaming, Folding, and of course day to day activities.
I'd wait. You may be suprised to find AMD fully embracing EFI with 1207. If nothing else, Intel may not be a bad choice in the near future with Conroe. Nothing you do could utilize 4 cores simultaneously, unless you have a burning desire to spend a ton of money just so you can do F@H all the time. Certainly don't get anything Intel now though.
if you didn't already know you were getting an Areca Arc-1220 you do now.
Newegg has the best deal. I have several Areca HBAs, and the ARC-1230 w/1GB upgrade is the fastest HBA I've ever used. Ever. Though, either way 250GB drives FTL.
🙁 I'd rebuild the array with
WD3200KS (cheap POWAR) or
WD4000YRs.. WD5000KS are supreme now, but definitely not cost effective.
For PSU wait for the Seasonic M12 700w modular.
If you do decide on Dual 940, i use Corsair CM72SD1024RLP-3200 RAM for my sig rig.
