jlee
That's a fair point. Given they shouldn't be pulling more than ~3500 or so, their trailer is most likely similar to the lightest one on this list here. For a ~3700lb trailer, the tongue is 290lbs. So basically that means leave the girlfriend at home so the car stays under GVWR 😀
Let's look it up together. 6500 pounds for the trailer.
Ford Ranger
"Regular Cab, Super Cab, Double Cab 4x4: Unbraked 750 kg*; Braked 3000 kg*"
3000kg is 6613 pounds. As long as your plastic cups and nylon underwear weigh less than 100 pounds, you're good to go :thumbsup:
did you miss this?
*In some situations 4L may need to be used.
Sure, you can tow it...if you want to move it across your yard.
