So I got Vonage -- UPDATE!!!
Tal
1,832
Ok. I consider myself pretty good with phone stuff. As long as the point at which the phone line from outside (Telcompany line) is not connected.... IE, when you pick up another phone in your house, you get nothing. Then you can plug your vonage device into the phone jack nearest it and should have signal to all of your other phones. Vonage actually talks about this. Broadvox and others have instructions to that effect I believe. Just make sure that when you pick up the phone that it's dead and does NOT get a dial tone. Otherwise you could mess up your vonage device. All your jacks in the house are connected up together, and so it should work just fine. The other thing to ensure is that you don't have any other filters on the line. Powered ones could cause damage, but non powered probably just could cause it to not work. Below is from the Vonage site:
Some Vonage DigitalVoice customers have plugged the ATA directly into the existing telephone wiring in their homes.
The manufacturer (Cisco) of the adapter does not recommend hooking anything to the adaptor other than a telephone, but you can seek advice from an electrician or someone who is familiar with internal telephone wiring on how to best connect it to your current wiring to take advantage of multiple extensions. We would advice that you pre-check the wiring on the jacks to make sure you don't have live PSTN voltage on the jacks before connecting them to the ATA (this can be easily done by using a line tester such as those that are available at Radio Shack). Be advised that any damage resulting from practices contrary to manufacturers recommendations for the ATA will not be covered by warranty.
I plan on disconnecting the telco line coming in (it comes in at my crawl space under the stairs) and hooking Vonage up to that as soon as I get it.... Good Luck! -Tal
T3C
5,324
So I take that as, as long as the lines are unhooked comming into the house, it should be fine, The line is disconnected at the DMARC.
minendo
35,560
22
Amused, are you on InsightBB? (For some reason I think I've seen you mention it before, but I could be mistaken.)
If so, how is the quality of Vonage? Do you suffer lags when on the phone?
Amused
57,387
19,676
None that I've seen. The only thing I'm worried about is Insight's crappy upload speed of 128kb. I've surfed while on the phone and it seemed OK. I haven't tried anything intensive, though.
I just got it hooked up today.
The voice quality is every bit as good as it was with the telco.
minendo
35,560
22
Yeah insight's upload sucks. Anything above 10 up saturates the line, that is why I was worried about Vonage.
Did you know insightbb offers a 384 up line?
Amused
57,387
19,676
Yeah, but that's not worth the $35 fscking premium they want for it. :|
Vonage seems to work fine for at least casual surfing. Which is all I do on the phone anyhow.
T3C
5,324
Do you have the option to go with DSL? I have DSL 1.5, my neighbor has Insight BB. Im able to browse and download ok well my gf is on the phone no problem. Where as my neighbor has to not use the pc well on the phone
Amused
57,387
19,676
CRAP!! I just found out I STILL have a dial tone on my telco line. I TOLD them to disconnect me completely.
I guess I'll have to call an electrition or telephone guy to physically disconnect me.
Any idea on what type of workman to call for this?
minendo
35,560
22
I have the option of DSL, but I refuse to deal with Verizon. I don't want a home phone nor do I want an 8 month contract on DSL.
Amused
57,387
19,676
No DSL here. I'm in a little town outside of Springfield.
Like I said, I haven't had a problem with surfing while on the phone. We'll see over long term...
djheater
14,637
The phone company. ;)
Even if a WORKMAN disconnects the line, you'll still have a dial tone... it just won't be on your jacks. It will end at the disconnection.
Think of it as water and the phone sytem as plumbing. The water needs to be turned off at the main (Telco)
T3C
5,324
I can understand that. I work for a ISP so I get 1568k for $20 a month and no contract, Would have cable if I didnt work for them.
T3C
5,324
Or just go out to your dmarc and unplug the line
Tal
1,832
do it yourself. Don't you know where the phone line comes in? You could even go outside your house and open the box there with a flat screwdriver usually and just cut it there. If you decide to hook up to a normal telco again later, they can fix that. I would just cut it.
Edit: And I mean the box on the side of your house..... not the one on the street. Just didn't want anyone to get arrested....
djheater
14,637
That's what the proposed workman would do... but this doesn't solve the underlying problem of the TelCo still providing service to the line. They need to shut it off.
T3C
5,324
you dont even have to cut it, it unplugs :)
Amused
57,387
19,676
Well, it's raining, dark and muddy out there tonight. I'll give it a go tomorrow.
T3C
5,324
Ahh come on, real men unplug there phone lines in the rain.. .... well I guess you might look kinda suspecious out there at night in the rain cutting a phone line :) lol
Amused
57,387
19,676
Well, that, and I have a new house with new landscaping. Makes for LOTS of mud. :(
nightowl
1,935
If you have access to the phone line where it comes into your house and connect the wire that goes to all of the lines in your house it should work. The main worry would be the voltage coming from the line from the phone company. So, if you find where the phone line comes into your house I say go for it. It should not hurt anything. On a side note, the Vonage box may not be able to supply enough voltage to ring every phone in your house if you have a large house with a lot of phones.
Amused
57,387
19,676
Well, I went out there and I was right. It's really muddy and wet.
The box was also crawling with big, nasty looking spiders. So I sprayed bug poison all over the box and around it. I'll give it a looksee when the rain stops and the mud dries up.
EvilYoda
21,198
9
Great thread...I'm looking into Vonage for my family right now, I was gonna post to see what some reactions were on the ease of setup and use since I won't always be around.
T3C
5,324
Super easy set up, Just plug it in. Have not had any problems with it sense I put it in.
