So how was your day?
AdamK47
3,630
My day is going better. The death of my loved one has been avenged by a mysterious rogue vigilante.
Kaido
Feb 14, 2004
51,992
7,419
I finally perfected my homemade ice cream recipe, so I'm looking forward to diabetees in my future.
Kaido
Feb 14, 2004
51,992
7,419
I've got a 16 y.o. He'll figure it out.
:D
Update! This recipe has been converted to sous vide for use in the Anova:
https://forums.anandtech.com/threads/i-got-my-anova-today.2360863/page-39#post-39107417
Okay soooooooooo. One of the redeeming aspects about living in this horrendously expensive state (CT) is that we have absolutely fabulous farmstand ice cream. New England-style ice cream is basically a thick & chewy type of ice cream...it's still very rich & creamy, but it's not...fluffy. And it is not designed for soft serve..you freeze this stuff. So it's a process. It's basically centered around a custard base, but with some extra ingredients to make it NE-style. I started with this article:
Serious Eats: Dense, Chewy, and Rich New England-Style Ice Cream Recipe
After a dozen or so batches, I've got it refined to where I want it. I've made three primary changes:
1. Evaporated milk has been replaced by whole milk
2. No tempering or slurry
3. Effort reduction using gadgets
The basic process is:
1. Cook (because eggs)
2. Chill
3. Churn
4. Freeze
I suppose you could make a batch in a little as a day if you started in the morning, but it really takes 2 or 3 days to properly make a batch (due to chilling & freezing). There's not a lot of actual work involved, mostly just...waiting. And you can always just buy vanilla Haagan-Daaz, which is excellent, for similar results. No real cost savings here due to the premium ingredients (lots of eggs, heavy cream, etc.). I like custom mix-ins (I better get a piece of cooking dough in EVERY BITE, dangit!), so making it at home is definitely worth it for me. You will need a fair amount of tools:
* Blender (or food processor)
* Instant Pot (3-quart or 6-quart model) ~$99 (check the Kohl's deal)
* Gourmia GST210R automatic stirring attachment (fits the 3qt & 6qt IP models, I've tested both personally) ~$30 (saves you ~20 minutes of stirring every time you make it, so it's worth it if you do it often...or if you make dulce de leche, which takes about 70 minutes of stirring, or risotto or whatever)
* Thermometer (I use a Thermapen knockoff - the Lavatools instant-read pen for $25)
* Medium or large fine mesh sieve
* Ice cream machine (recommend a 2L freezer-bowl or chiller model, I use a Cuisinart ICE-30BC)
* 5-cup Rubbermaid dry food container (~$6 a pop, I have a half a dozen for personal inventory...they are great because 1, they are long & flat so the ice cream freezes quick without getting ice crystals, 2, they are awesome for doing swirls & mix-ins easily, and 3, super easy to scoop up a nice round ball of ice cream length-wise)
"Butterbean" farmstand ice cream recipe:
Special credit to Max Falkowitz of Serious Eats for the pioneering work on this (particularly the corn syrup & arrowroot starch combo).
8 Egg Yolks
1 & 1/2 cup Heavy Cream
1 & 1/2 cup Whole Milk
3/4 cup Sugar
1/4 cup Light Corn Syrup
1 teaspoon Vanilla Extract (note: cut that in half if using strong, high-quality vanilla extract)
2 teaspoons Arrowroot Starch
1 teaspoon Kosher Salt
Directions:
1. Blend all ingredients on low-speed for 30 seconds
2. In the Instant Pot:
a. Pour mixture in
b. Set to YOGURT > BOIL (the IP is induction-heated, won't scald the milk here)
c. Attach the Gourmia & set to Speed 2 ("fast" stir). If you don't have a Gourmia (or IP), you can just stir it by hand...manually...with a whisk...which feels like forever...ugh.
3. Bring up to 170F:
a. Set a timer for 18 minutes
b. Check the temperature. You want at least 170F, but you don't really want to go over that. 180F makes the ice cream taste weird.
4. Chill:
a. Strain hot mixture through sieve into a lidded container (saran wrap & rubber band is fine for a lid, if you're using a large bowl) to go in the fridge.
b. Optional, but recommended: "shock" the container in a bowl of ice water to stop it from continuing to cook (brings the temp down quickly), then move it to the fridge.
c. Goal is to bring it down to 40F. Pretty much just let it sit overnight in the fridge.
5. Churn:
a. Pour cold mixture into ice cream maker (if using a freezer bowl machine, freeze the bowl 24 hours beforehand).
b. Let it churn for 30 minutes. At this point, it will be soft-serve. This particular ice cream base is designed for freezing, in order to become scoopable, not to be eaten at this point (texture isn't right). There are other, better recipes for doing homemade soft-serve or "creamy-only" ice cream, like this great one from Alton Brown.
c. This is the point where you can do mix-ins & swirls. See this article for some good tips on ratios & techniques. I usually do one to three layers of mix-ins between spooning out the ice cream. Here are some good recipes:
1) Fudgy brownies
2) Eggless cookie dough (note that the FDA has warned about flour...heating the flour first to kill any e.coli...so it's not just about the egg risk; here's a microwave technique)
3) Dulce de leche (stir attachment is well-worth the money here, and yes use the goat's milk!)
4) Blueberry compote (note: I only use 1/2 tablespoon of lemon juice, and I use the bottled kind)
6. Freeze for at least 6 hours, preferably with your freezer set to the lowest, coldest setting.
Notes:
My procedure typically goes like this:
1. Blend up the mix & cook it after work
2. Shock it in a bowl & then let it chill in the fridge overnight
3. Churn it before work the next morning, add mix-ins, and then throw it in the freezer
4. Enjoy when you get home from work
So it's not a quick process, but it makes a very high-quality, dense ice cream that you can customize with whatever mix-ins you want. I'm currently experimenting with a chocolate base, although that's not ready for a public recipe quite yet. This ice cream base has so much vanilla flavor & is so buttery that you can throw in some pecans (try this toasting technique, or even better, throw in some candied pecans) & basically have a super-easy Butter Pecan ice cream.
It's pretty easy once you get the hang of it, and especially if you get the $30 auto-mix attachment for the Instant Pot (works on regular pots too!). I've been making ice cream every week because it's so hands-off. This is similar to the way you make yogurt in the Instant Pot...you boil the milk, chill it down, stir in some yogurt (to act as a starter for the yogurt bacteria), incubate it for 8 to 24 hours, and then strain it. It's a long process but the actual hands-on time is like, minutes, so if you're willing to either plan ahead or just schedule it on your calendar, you can make fresh batches of yogurt & ice cream every week! (bonus, you can do froyo in the ice cream maker using homemade yogurt!)
Reactions: highland145
highland145
43,973
6,339
2. Chill
3. Churn
4. Freeze
8 Egg Yolks
3/4 cup Sugar
Directions:
a. Pour mixture in
4. Chill:
5. Churn:
1) Fudgy brownies
Notes:
Ho
Lee
Sheet
I bow to my Kitchen Overlord.
Think I'll skip zinfamous' next week and come see you. Is that enough time for a churn?
Thanks.
Reactions: Kaido
Kaido
Feb 14, 2004
51,992
7,419
Mosh has dibs on the winners of this weekend's Great ATOT NE Cookie Bakeoff, so I should have some extra freezer goodies available outside of that :kissing:
highland145
43,973
6,339
That girl shouldn't have sweets...dental cleanings and all. I'll just take hers. Cool?
I had a nice day at home :) I have a short vacation from my work at the current time because of some problems with my health so today I made a couple of things and had a good rest :) The only thing which makes me a bit sad is that it's very hot in my city during the last several days :confused:
Come to America. Very hot. Not as hot as me but still....
:p
+1 on your health.
Kaido
Feb 14, 2004
51,992
7,419
Minor eff up or Freudian?
:D
so help a Luddite out...#TeamNE...?
New England represent! ;)
Operation Kringle was meant to kick off last year, but got moved back because the judging has been...extensive. Should be ready in time for ATOT this holiday seasons. Can't say much about it other than it will be the ultimate Thread of Carbs :D
Kaido
Feb 14, 2004
51,992
7,419
debating on getting an occulus rift
I think you'd have a blast with it...it's pretty dang trippy. For you, I'd recommend Senza Peso for your first VR experience (that is, if you haven't used VR before). Don't look it up, just download it & experience it if you get a VR HMD.
Does your computer have sufficient specs to run VR btw? The minimum requirements are unfortunately pretty high ($).
13,940
Made ice cream in science class when I was in high school, was actually not bad. Basically it involved milk, sugar, and liquid nitrogen and other random stuff we threw in it. We went around school asking if anyone wanted to try, when it was deemed safe, we tried it too.
Kaido
Feb 14, 2004
51,992
7,419
There's a couple places around here that do liquid nitrogen ice cream, it's REALLY good. Zero ice crystals. I went here the other day & it was super amazing:
https://www.facebook.com/assemblymarlborough/
They actually do real-ingredient flavors, which is pretty novel this day & age:
http://www.newhampshire.com/article/20151025/NEWHAMPSHIRE07/151029444
The texture is pretty wild...it's served at something like -326F or something nutty & it's just perfectly frozen & creamy. It's not even so much about the taste as the texture...you just have to keep eating it to keep trying the insane smoothness of the ice cream.
Ajay
16,094
8,114
That stuff is good, can't remember where I first had it, I think it was the Deerfield fair.
#TeamNE
#CowHampshire :D
