So Dirt 2 officially ROCKS!
shortylickens
80,287
17,080
Yous guys can gets a gamepad of 360 style for a mere 30 bucks if you search around.
Not only is it good for sports games, but its nice for platformers like Braid.
AstroManLuca
15,628
And 3rd person action/platformer games like Dead Space, Resident Evil 5, and Devil May Cry 4, etc. A lot of those games have really bad keyboard and mouse controls.
simonizor
1,312
I got this game on the sale this weekend and I love it. They aren't trying to force you to use the game pad; it just works much better than keyboard and mouse and they expect most normal people to use either a game pad or a racing wheel. I'm using my PS3 controller with the MotionJoy drivers, and it works just like a 360 controller in the game.
I really like the variety of tracks, the game types, and pretty much everything else about the game.
The way that they use the racer's voices in the game to make it seem like you're actually competing at the events is pretty cool.
There aren't a whole lot of vehicles, but each vehicle is better at certain event types, so it's not like you're driving one car all the time.
The only thing that bugs me about this game is that the current version of Games For Windows Live doesn't work properly with this game on XP x64. When you launch the game for the first time, you will not be able to make an autosave. Without an autosave, you cannot save any of your progress in the game. The only way to make it work is to install an older version of Games For Windows Live to play single player, and then install the new version if you want to play multiplayer. Of course, if you want to play single player again you'll have to go back to the old version. I just installed Windows 7 again lol.
It is great, but I really need a controller/racing wheel. Damn PS3 controllers take way too much to work and then don't even work.
Have you tried getting MotionJoy? What OS are you using? First you plug in your controller and let the default drivers be installed. Then you install MotionJoy just like any other program. Reboot your computer. If you're using Vista/7 x64, you'll need to hit F8 during boot and go down to "disable driver signing" (or something similar to that), and hit enter on that. After you do that, you go to the folder in your start menu that MotionJoy made, and go to "Install MotionJoy driver", right click on it, and go to run as administrator. After you've installed the driver, then run the DS3 Tool program. If your controller is working properly, it will say "Connected Game Controllers: 1. Game Controller." Under "Select One Mode", select "Xbox 360 Controller Emulation", and hit Enable down at the bottom. You should see something in your tray saying that an Xbox 360 Controller has been detected and installed. Then just minimize MotionJoy, launch Dirt 2, and enjoy.
To anyone who says that the controls aren't good, I have absolutely no problems controlling it with my PS3 controller. If you're using a keyboard, the controls probably suck because you can't select the amount of gas that you're giving the car; it's either all or none. When you're going around corners (especially dirt/gravel ones), if you give your car full gas, it will most likely drift excessively and cause you to spin out. If you're using a controller or racing wheel, you can give your car any amount of gas that you want to, so you can control yourself around corners much, much better.
Tristicus
8,107
61
www.wallpapereuphoria.com
I've tried MotionJoy over and over and it is a horribly setup program that never worked for me. I might try one more time, as most of my tries were with Vista, but the software never recognized my controller via bluetooth or plugged in and I found it to be a POS.
simonizor
1,312
Are you using x64? You absolutely MUST hit F8 during boot and select "disable driver signing" before you install the driver that is in the start menu folder. After you do that, right click on the "Install MotionJoy driver" program and select run as administrator. The first time that you set up your controller, you need to have it plugged in. Then you can go to the bluetoothpair tab and pair the controller with your computer. Following the instructions that came with the program, I have had no problems using this on both XP x64 and Windows 7 x64. It is not a "horribly setup program" or a "POS"; you just need to follow the directions, all of them. In fact, this program is great. It saved me the money of having to buy a wheel or a 360 controller since my PS3 controller is now detected as a 360 controller by windows, so it works perfectly in not only Dirt 2, but also any other game that supports a 360 controller.
Tristicus
8,107
61
Well this new driver must be better than the old ones because it's emulating a 360 controller (at least in GTA4 for now) after many restarts. Just tell me I don't have to force signing on each restart...
Working with Dirt2, though I might be better with the KB actually...
Also, does cockpit view feel real cramped to anyone else? If I had the money I'd consider a wheel, but I'd want to be in cockpit view for the full experience...but it seems so limited. The water also annoys me.
AstroManLuca
15,628
Okay, this game is fun, but everything other than the racing is pissing me off.
Upon first launch, it sets itself to 800x600 resolution and starts a long string of unskippable cutscenes. Once all of them are over, you can change the resolution (that is, if you can figure out the weird two-level first-person menu system). At that point you must do your first race because the Quit option doesn't appear in the menus until after you do it. And if you force close, it loses your progress and forces you to rewatch all the unskippable cutscenes and wait for 5 minutes while it "connects to Dirtnet" all over again.
During the races, other racers I don't care about yell various stuff at me. Also, after every single race, one of those other racers either congratulates or consoles me based on how I did. And while they're doing that, you can't do anything. When you unlock something, a voice actor will tell you what you unlocked, and again, while they're talking, you can't do anything. You can even mute the voices, but it doesn't change the way the menus act.
At the end of every race, and often multiple times during a race, you'll go over a jump and fireworks shoot out of the ground. This was maybe sort of cool the first two times, but it gets really old.
There's an XP system that unlocks new events. When you level up, the new number SLAMS in very loudly and makes the entire screen SHAKE violently and FLASH. This is pretty extreme but man, I am so over that shit. I just don't think I'm extreme enough to handle it.
If the racing itself wasn't so damn fun, I'd tell David Mirra to shove his stupid sideways hat up his ass.
Skurge
5,195
totally agree with this.
Can we organize a jam session? I usually end up with a some French or German idiot shouting over the MIC
My live ID is Ax0n404
AstroManLuca
15,628
Sure. I'll try to remember to add you when I get home today. My Live ID is ItsaMamaLuigi. Not sure exactly when I'll be on but I'll make sure I have some free time when I do sign on and we can do some racing.
AstroManLuca
15,628
You sound mad.
The game launches fine for me and only goes to windowed if I alt+tab to which I reply alt+enter. All things are skippable for me. Voices can be turned off.
No, just venting a little because it threw so many annoying things at me in quick succession when I first tried to play it.
It wasn't an 800x600 window, it was 800x600 full screen until I changed it. And the first cutscenes that play when you create a new profile are definitely unskippable.
After the first run, it's not that bad. If it was, I wouldn't keep playing it. At this point there are only very minor annoyances in the menus, nothing big.
watek
937
Waiting for my 360 controller to enjoy this game. Using the keyboard just a pain in the ass haha.
simonizor
1,312
The voice actors are used mostly during loading times, so if they weren't there talking to you, you'd be sitting in silence. If you look at the corner of the screen, the loading icon is there most of the time when they are talking about stuff that you've unlocked. I think the voice actors add to the game quite a bit. I like how they talk to you during a race; it doesn't interfere with anything, and most of the time you can get a laugh out of what they say because it's so cheesy.
BD231
10,568
138
Katie Justice keeps challenging me and I beat her every time...so this time I spun her out in the first 250 feet or so. :awe:
lol, I to find hitting other players is pretty damn fun in this game.
The finish line has nothing to do with my style of racing :sneaky:
destrekor
28,799
359
So my favorite form of racing, Rally, is by far the most challenging. Yeesh, had to back down from Savage (4th difficulty? out of 6?), to Serious (one lower), just to stand a chance on the Rally events. Consistently a few seconds slower, when all the top 5 are all 1 second from the top time. That's NOTHING like Rally. Bastards. :D
Anyhow, love the game.
This plus G25 (using h-shifter, clutch is pointless, not using clutch hasn't given me much bonus it appears), is awesome.
Thought I was going to hate the circuit and other race events (ones with cars around you), but I've already grown to like them after only a few.
No problems visually.
Windows 7 x64, latest drivers for my GTX 285... runs perfectly. :)
Apr 20, 2008
10,067
990
I'm so surprised the game runs well maxed out (well, DX10 maxed) on my 4830 512mb. 1680x1050 4XAA High/Ultra everything. Runs near silky smooth. There are some slowdowns at the start when we're all bunched up, but with 4 or less cars it's great.
minmaster
2,041
got in on the sale, and i have to say there are way too many loading screens just to get into a race, i mean it feels like they ported the long and constant loading screens from the consoles... too much BS to go through to just have a simple race... ugh
Oct 27, 2007
17,009
Loads really quick on my machine.
Skurge
5,195
the only loading screens I notice are between races. and even then they only last a few secs.
minmaster
2,041
they definitely last more than few secs... and constantly bombarding you with useless info about silly achievements.
thegimp03
7,420
I might have to pick this up...though I still have not finished Forza 3 and I haven't played it since I picked up BFBC2. Blah too little time.
