So are there more even numbers than odd ones?
oboeguy
3,907
Lots of good math people answering here. How about a trivial proof that there are the same number of evens as odds, degrees of infinity aside? For each even number you get a unique odd number by adding one to it, and vice versa. QED. :D
Legendary
7,019
Originally posted by: Nik
Originally posted by: RaistlinZ
Yeah, what about 0? Given that there is no -0 and that 0 is an even number, there will always be one more even number than odd number.
Bingo.
Edit: looked it up, apparently zero is even. My mistake.
Howard
47,982
11
Starting counting even/odd from zero, then.
{0,1} is the first set, {2,3} is the second... then there are an infinite number of sets if we're talking about non-negative integers.
SpecialEd
2,110
here we go...
write out all integers ...-3, -2, -1, 0, 1, 2, 3....
Lets assume 0 is even.
just group every two numbers based off the group {0,1}
we get ..., {-4,-3}, {-2,-1}, {0,1}, {2,3}, {4,5}, ...
Clearly there is 1 even and 1 odd in every pair.
Thus there must be the same number of even and odd integers.
edit: I didn't see you post howard. Good job.
SinNisTeR
3,570
there are the same amount..
what about rationals vs irrationals? ;)
same
sqrt of any number that is not a perfect square
rationals have a countable infinity, while irrationals do not. there are different types of infinity.. :)
i dont understand how you can count the rationals
.01 .001
.0001 .00001
isn't there an uncountable infinite number of rationals between .01 and .0100000000000000000001
now if you are talking integers that is one thing but rationals is another
i like to draw a little table to visualize it better..
-----1---2---3---4---5---...........
1- 1/1 2/1 3/1 4/1 5/1
2- 1/2 2/2 3/2 4/2 5/2
3- 1/3 2/3 3/3 4/3 5/3
4- 1/4 2/4 3/4 4/4 5/4
5- 1/5 2/5 3/5 4/5 5/5
for irrationals you have things like square root 2 and pi. etc. those all fit in between all rationals, ifinitely packed.
think of this graph
f(x)
0 while x = irrational
1 while x = rational or p/q while q != 0
what does it look like?
picture an xy coordinate system with
y=0 completely covered, a solid line pretty much and
y=1 very dense line ............ with little holes pretty much.
make sure you zoom in on it
if you put y=1 on top of y=0 you get the Real number system :)
eigen
4,000
The number of evens equals the number of odds because you can form a bijection between the two....
The kicker is this... there are as many even number as there integers .....
