- Feb 14, 2004
- 52,373
- 7,634
- 136
intraHouse project for home automation http://intrahouse.eu
аnd demo http://intrahouse.eu/demo
Nice web interface
A couple questions:
1. Is this available in the US?
2. Does it use entirely custom controllers?
Nice web interface
Its hard to understand what this thing actually is.
Seems like its just a small tablet that lets you modify all your other smart locks/lights and whatnot.
If this works as well as I think it might, then this will be HUGE, especially since they've partnered with Home Depot. Imagine running down to the local big-box store, picking up a hub & some devices, and getting everything setup in a free afternoon. Super awesome. This could be the next Veralite device...
That's pretty much my take on this. The one thing I noticed I don't see much word about is camera support. Not a deal breaker for me but I guess it's better if this can do everything else well..
A couple questions:
I pre-ordered the Link Hub & 2-pack Link LED combo for $49, so I'll see how that turns out. I'm in a rental right now and just finished setting up the half-finished basement with my LED projector for my micro-sized home theater & needed some lights anyway, so this will be super convenient since I can control everything through Wink (lights), Roku app (Netflix), and the Logitech Harmony Smart Control IR blaster (5.1 receiver & LED projector) via my iPhone - pretty slick. Simple touchscreen remote, no gimmicks. And for $79, I'll definitely be picking up a Wink controller - that's a lot easier to justify than one of the near-$200 Zwave-only controller hubs, especially since it has support for BT, Zigbee, Wifi, Zwave, etc.
I can't wait to hear your thoughts after getting it. :thumbsup:
Keen has a neat idea: individually-controlled smart vents for your HVAC system:
http://www.keenhome.io/
Yeah I'm curious if it goes to last state or turns on at 100%. Good question! Now that you bring this up.. I wonder how this works for all these smart bulbs...One thing I'm curious is how it will with existing technology. So my basement has 3 wall lamps and 1 floor lamp, for a total of 4 bulbs. Wink can control all 4 bulbs individually or as a group via the Wink app through the Wink Hub (iPhone to Wifi to Hub). But what if I want to use a wall switch? Do the bulbs auto-detect power? So if I walk out of a room & flip the wall switch off, that will cut power to the Link bulb, turning it off. If I walk into a room and flip the switch on, is it smart enough to turn on when power is applied, or does that simply enter it into a state where it can receive Wink commands, so nothing happens?
I'd imagine it has a power detection feature, and then from the "max brightness once power is received" state you can control the on/off/brightness level via Wink. I know INSTEON has some in-line micro modules that you can wire in inbetween the wall switch & power line to communicate the lamp itself:
http://www.smarthome.com/2442-222/INSTEON-Micro-Dimmer-Module/p.aspx
GE (Wink) already has a plug-in dimmer adapter, so that would be good for the floor lamp since I wouldn't have to replace an outlet or anything:
http://www.amazon.com/GE-Z-Wave-Wire.../dp/B0013V6S0Q
Although they do have outlets already available as well, which I'm assuming would be Wink-compatible because they're from the same manufacturer:
http://www.amazon.com/GE-Wireless-Li...dp/B0013V1SRY/
They also have wall switches:
http://www.amazon.com/GE-Z-Wave-Wire.../dp/B006LQFHN2
What I'd really like is a center-sprung momentary wall switch with an LED light built in. I've used transparent light switches with an LED built-in, so you can see where they are in the dark, which is SUPER handy:
http://www.homedepot.com/p/Leviton-...l-Toggle-Switch-Clear-R57-01223-0LC/202027025
But for a smarthome application, it'd be ideal to have a momentary switch that springs back to the middle. So if you flick it up, it sends the "on" command and then returns to center. If you flick it down, it sends the "off" command and then returns to center. And then you could program in like a 2-second hold for "all on" or "all off". They have some large rocker switch panels & touch button that do stuff like that, but I don't find them very intuitive - I like having a standard flip up/flip down switch, and if they could do a Zwave-enabled model that did that, that would be the best because it's the same old switch you're used to, just a little better. Ideally with backup functionality to function if the Hub is down as well.
An engineering project I did in college had a smart vents like this that learned where you were in the house at what time of day and controlled the temperature so you weren't wasting energy cooling/heating rooms that didn't have anyone in it.
Wink is the one quick and simple app that connects you and the products you rely on every day in your home.
It uses a smart and intuitive interface for easy control of connected devices like lights, locks, thermostats, smoke alarms, cameras, sprinkler systems, and more from these leading brands: Bali, Dropcam, GE, Honeywell, Kidde, Kwikset, Lutron, Leviton, Schlage, Philips, Quirky, Rachio, and TCP.
Wink makes setup clear with step by step guides and videos. If you ever need help with anything, you can talk to a real human on our customer support team 24/7.
Wink is free to download and doesn’t charge any fees for use.
Many products work directly with the Wink app. Other products use the Wink HUB to get connected. The Wink HUB allows your diverse collection of smart products to speak the same wireless language so you can control them --and customize their interactions-- from the Wink app.
Features:
Shortcuts - Make simple buttons to quickly access your favorite settings.
Robots - Automate your home by building virtual robots to do things for you.
Activity - Schedule and monitor everything in your home.
Of course, these won’t be Kaufman’s only competitors. Apple’s HomeKit certainly looks like one. But Kaufman insists HomeKit is an opportunity for Wink, not a threat. “HomeKit’s a developer platform. It makes things like Wink work better,” he says, explaining that Wink could tap into Apple products like Siri and touch identification. Plus, Wink would benefit from the fact that it can work even with products that aren’t HomeKit-enabled.
Better deal: go to Home Depot and buy two Wink-compatible devices (you'll need them anyway right?) And get the hub for $0.99.Whoohoo, it's Wink day! Amazon has the Wink Hub for $49:
http://www.amazon.com/Quirky-PWHUB-W...dp/B002YVHYF2/
The version 2.0 app is available on the iTunes store:
https://itunes.apple.com/us/app/wink-instantly-connected/id719287124?mt=8
So you can use 4 types of controls:
1. Manual control (push a button)
2. Shortcuts (for quicker access to stuff you use often)
3. Robots (simple IFTTT-style programming for creating chains of commands)
4. Activity (scheduling actions, such as turning on the bedroom lights at 6am
The Android version has been updated as well:
https://play.google.com/store/apps/details?id=com.quirky.android.wink.wink&hl=en
Great article on Wired:
http://www.wired.com/2014/07/wink/
Support information:
These guys are serious: the app is updated, the equipment dropped today at a good price, and they have free live help. Who the heck has free live help? Haha.
...considering that the IoT market is projected to reach 212 billion devices by 2020, it's pretty much guaranteed to be a huge mess if products continue to run independently of each other. One universal spec allowing interoperability across all kinds of devices would help to simplify things, and that's what Intel, Dell, Samsung and other tech giants hope to achieve with the just-announced Open Interconnect Consortium.
The new OIC, on the other hand, is more concerned with consumer and enterprise use cases (at least for the time being), and it will produce an industry standard to improve device-to-device connectivity. According to Intel, the participating companies will develop a certification program along with the new IoT protocol spec. The OIC will initially focus on open-source code for smart home and office scenarios, with specs tailor-made for connected cars and the healthcare industry to follow. For consumers, though, the bottom line is that connected devices could someday be sold with a OIC sticker on the package, letting you know that the smart door lock you're eyeing meets the consortium's requirements for interconnectivity.
Btw the nest thermostat is $230 now http://www.amazon.com/Nest-Learning-...&keywords=nest
