Skyrim - 560ti runs better than new 7950?
Rvenger
Elite Member <br> Super Moderator <br> Video Cards
Apr 6, 2004
6,283
OP, you could have overwritten your existing drivers. 99% of the time it doesn't hurt anything. The only time when it could pose an issue is when you overwrite every single driver iteration from a year ago. If you are running Windows 8 your not the only one with issues, especially if you used the official uninstall tool.
Mogadon
739
What exactly entails a "clean install?" I completely uninstalled the 13.1's using AMD's uninstall tool from the control panel. Then downloaded and installed the 13.2's. Not to fuel this AMD/Nvidia war, but when I update my Nvidia drivers I usually just go right over the top of the previous ones(not the greatest practice I know, but i've never had any issues.) It seems a little ridiculous if I have to do more than using a tool that AMD provides.
I'm not weighing in on the manufacturer war but what you're saying with regards to updating AMD drivers is wrong.
As I indicated earlier in the thread, there's no requirement for a clean install when updating AMD drivers. If you have CCC running you can go directly to the update utility and simply follow the prompts. I don't think there's even a requirement for reboot, although you may want to.
I just wanted to clarify that so people don't think, as you may have been misled to believe, that a clean install is a requirement to update AMD drivers (we don't want to add fuel to the fire here).
I have three machines running AMD cards and have not done a clean install for about a year when updating their drivers to the latest version.
The idea you need to do a clean install seems like a throwback to pre-2012, when this functionality was not built in by manufacturers. I'm sure there are instances when things may go wrong and a clean installation becomes a solution to a problem, but for a regular update it just doesn't seem necessary, as the functionality is built right into the product.
UaVaj
1,546
unless it is a true standalone program. video driver obviously not standalone.
uninstall does not = 100% removal. hence the need for clean install.
post #9 and #14 clearly proves clean install with the latest driver fixes the issue.
