Skylake AVX bug
The Stilt
1,709
3,057
MS does for Windows but not very often, usually for critical fixes.
Example of AMD microcode and Windows.
https://support.microsoft.com/en-us/kb/2818604
Pretty interesting that they have been providing µCode updates for those crappy Bobcat APUs, especially when they did not provide one to fix the critical issues which Bulldozers had... I guess it would require some activity from AMD side too in order to MS be able to distribute the updates in the first place :rolleyes:
Elixer
10,371
762
Intel must have extensive test suites, and a huge budget...You do have to wonder, how did this one slip by them?
It isn't like programs like prime95 are rare, so, who dropped the ball on this one?
2,012
That's a really good question...
Nothingness
3,374
2,475
Why, "version 1.1" will have errors. There isn't going to be any change to Skylake CPUs. This issue is fixed, new will come. Its how it is with all MPUs.
No, it's no how it is with all MPUs. New Intel steppings sometimes include fixes for some errata. It's rare, but it happens.
Dresdenboy
1,730
554
citavia.blog.de
It's just actually impossible to completely verify a modern CPU.
This is not the same as testing different code paths of existing and well known CPU heavy software. But as forcing a specific FFT size to be used for hours is more than running the built in standard tests, this might simply have been missed.
zir_blazer
1,266
586
zir_blazer
1,266
586
More fresh meat.
The very first 386 Steppings had some critical flaws running Protected Mode (32 Bits) Software that made the system to hang. Intel recalled them, tested them, and remarked them with a double sigma symbol, or "16 BIT S/W ONLY". The Windows 3.10 errors for defective 386s are rather amusing.
There are even comments that ocassionally Intel has been extremely tight lipped about errata, like for the 486 era. And please lets not even get started talking about undocumented instructions. The 286/386 LOADALL history is rather interesing.
That blog is really tasty...
Dufus
675
119
101
Seems Intel had a spot of trouble finding this bug because it was already fixed with the microcode they were using to test for it (ver 0x6A). Well, that's the story. :/
Brunnis
506
Asus just launched BIOS 1602 for the Z170-A, which I have. As always, Asus is vague about what's fixed ("stability improvements"), but it appears to include the new CPU microcode. I've run some tests (Cinebench, 7-zip, Sunspider and Geekbench) and at least in those tests there are no performance regressions. Running AVX code is perhaps the most interesting test and I'm not sure if any of the above mentioned use AVX... Does anyone know?
ShintaiDK
20,378
CB doesn't, and I really doubt GB does due to its poor x86 support.
Just run something like Linpack before and after. But there is no information that it should affect performance.
You can also use encoders. They tend to use AVX as well.
Brunnis
506
Nah, I had some benches from when I upgraded, so just thought I'd re-run some of them to make sure. The microcode is already applied, so can't really make any new comparisons now.
Didn't expect any performance implications, though, and I'm glad these limited tests confirm that.
