punjabiplaya
The K&N filter is the worst part of CAIs.
shh
Perhaps I should add that it gets better fuel economy and is more reliable as well.troll much? Good luck with your K&N...and make sure to put a sticker on your car that says "My Civic eats Mazda 3s for lunch"...it will give you at least 1 extra HP as long as it does not cover up your VTEC sticker in any way.
And then?Perhaps I should add that it gets better fuel economy and is more reliable as well.
No and then.And then?
More stickers = more horsepower...so all power to you.
Fine. So all I'm gonna put on is a K&N drop-in filter. You guys do realize that my car has a faster 0-60 time than a Mazda 3, right? It's not that slow. The autotragic Civics take 10s to go 0-60, but in a manual my car does it in a little over 7s. It's not bad really.
So you have a manual Civic Si?
And then?No and then.
ugh, what a nightmare
and then?
No no...I don't want to "rice" my Honda. Do you own a Mazda 3 by chance?
IIRC there was a user SickBeast who had an 8th gen civic as well. weird.
BEHOLD my true form!!!
Should I put a cold air intake on my Civic?
Fine, you know what? I'm gonna wait until Apexi makes a drop-in filter for my car.
Actually, this one has much more surface area and its open-celled structure is fine-tuned for the perfect balance between filtration (to keep the engine spinning at high RPMs) and flow rate, to allow your air-starved engine the ability to regulate its own fuel usage for maximum power. Plus, the dual-layer media allows a three-fold increase in lifetime due to segregation of differently-sized particulate matter, which prevents filter clogging.Try this one, it has way more surface area!
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
