Originally posted by: dfdave12
How does this Macbook look?:
2.4GHz Intel Core 2 Duo
2GB 667MHz DDR2 SDRAM - 2x1GB
160GB Serial ATA Drive @ 5400 rpm
SuperDrive 8x (DVD±R DL/DVD±RW/CD-RW)
Apple Remote
AppleCare Protection Plan for MacBook Air/MacBook - Auto-enroll
AirPort Extreme Card & Bluetooth
= $1,401 w/ my student discount.
Not a bad deal if I do say so myself.
Apple Remote
That's a horrible deal for the specs you're getting PC wise, LED included. I thought you were going the Thinkpad route in the other forum. May I ask why you decided to pay the cool tax?
Also, you stated in another topic that you wanted to be able to play some games, has this now changed? It only comes with integrated x3100 right?
I never said intense gaming, I meant any gaming. Also, I'm assuming that's a new macbook with the new Penryn chips. Remember, you're getting only 3MB of L2 cache(2.4GHz=T8300) as opposed to the 6MB found on &9xxx series chips. Also the drive is only 160GB @ 5400 and will be the bottleneck of your rig. I'm not sure what the comment about RAM is referring to.
The same specs would run you around $750 on a 14.1" Widescreen or Standard(I suggest this for docs) T-series. Dell also has amazing rebates currently on Vostros. You can even get one with Linux installed and put windows on that like you would on the macbook.
EDIT: I just noticed that Mac runs Microsoft Office 2008. This is done without even having to Bootcamp, correct?
Originally posted by: Spartan Niner
Build a Hackintosh.
Originally posted by: tommyz
I purchased my first mac, a Macbook. It's OK. I use it mostly with Windows XP.
I wanted to give Apple a try. This is probably the last Apple I buy.
1. I have had problems trying to get compatible memory for it.(I am not spending $600 dollars to upgrade with Apple memory)
2. The trackpad on the macbook sucks! It is very jumpy and only has ONE button!
3. There is not hard drive activity light.
4. I have had some crashing issues(Gray screen of death on the OS X side). So far no crashes on the Windows XP partition.
5. No support for my Samsung Laser printer in OS X.
6. There is more freeware and opensource software on the Windows side. It seems everytime I'm looking for an app for OS X, someone is changing for it.
There have been other issues, but the above are the biggest.
If you are going to be mainly using the Windows software get a Windows based machine. Again a single button track pad, are you kidding?(BTW OS X support a multi-button mouse)
I'm really thinking about holding off till the summer when the Macbooks get updated...hoping for 2.5ghz...
Can anyone convince me otherwise..? 🙂
Originally posted by: Tyranicus
Apple did say that all their screens will be LED-backlit by the end of the year, so that is a good reason to wait.
Originally posted by: dclive
- If the machine crashes, take it to Apple, no questions asked!
