Senate rejects Universal Background Checks
Page 14 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Fern
26,907
174
The current system keeps track of new sales only for guns. There is a record of what gun is transferred and to whom. But it's for new guns only. So if a person, who is legal to own a gun, doesn't want to have a registered gun on the system they can do so by purchasing a used gun. Still, it's an infringement but not as severe.
-snip-
Are you sure?
I've purchased several used handguns from a FFL and I didn't see any difference in the process.
Fern
piasabird
17,168
60
Most of the people that are stopped due to a background check are false positives. The system should at least be 80% or 90% accurate before we use it. I think they estimated that the background check system is wrong 90% of the time when it stops someone from purchasing a weapon.
If you really like the background check system, then use it at the voting booth.
HumblePie
14,665
440
Are you sure?
Fern
If you make any purchase of a firearm from an FFL, either used or new, you must fill out a 4473 form. I was just thinking of only new gun sales since I don't usually buy used guns from FFL dealers.
Private individuals can chose to use an FFL dealer to do a transfer right now. Some do and some don't. But any time someone with an Federal Firearm License is part of the transfer of ownership of a firearm, the person obtaining the firearm must fill out a form 4473.
While some private transactions use FFL dealers to do a transfer, it is not required. So some do not use an FFL dealer to do a transfer.
ivwshane
33,525
17,031
The system is around 98% accurate. Again I posted the data for all to look at. Can we stop pulling numbers out of our asses now?
https://www.ncjrs.gov/pdffiles1/bjs/grants/239272.pdf
HumblePie
14,665
440
haha, the same logic can be applied. The voting rights amendments state citizens instead of people. Which means a legal definition of citizens are only those that are law abiding and of sound judgement. Which means if you can legally force people to fill out a 4473 form to purchase a firearm, the same standard of vetting can be done before one can vote.
corwin
8,644
9
98% accurate where? According to the data there:
The remaining denials (71,410, or nearly 94%) did not meet referral guidelines or were overturned or canceled.
Nearly 94% of the denials were overturned, cancelled or were not referred to be investigated for some reason, only a little over 6% of the denials were valid:colbert:
Well fuck me it gets even worse...
Field offices investigated a total of 1,923 unlawful possession cases that began in 2010. A retrieval of a firearm (or firearms) from a prohibited person by field agents occurred in 1,164 (about 61%) of the cases. The subject of the investigation was cleared in 509 cases (approximately 27%).
Even 27% of the ones they went after were cleared:rolleyes:
HumblePie
14,665
440
Umm, the actual denials for 2010 were 76,142. The amount of NICS applications was 6,037,394. So the amount of denials compared to approves was only 1.2%
Out of those 76K denials, only 4,732 was not turned into proceeds within 24. Those 4.7K denials were turned over to the ATF for further investigation. The other 68K were not.
Out of the 4,732 initial denials 2,265 ended up being delayed denials. Meaning they eventually the firearm was sold to that person. Only 2,467 were actually DENIED in 2010. That's it. Clear as day on the table. They list WHY they original 76K denials were done immediately by NICS. Most were false positives to things like a felony conviction.
So 2,467 ACTUAL legit denials out of 76K initial denials by NICS that were then acted upon by the ATF.... you do the math.
HumblePie
14,665
440
Don't bother. He can't read tables.
He can't fathom the possibility that the vast majority of denials are because the NICS system responds immediately with the first record for a person matching the name given in a system. Many people applying on the form 4473 do not put their social. Which helps with clarification of who you are exactly, but it is an optional field. If a gun buyer happens to have the same name as a person with a felony conviction, they are going to be initially DENIED by the NICS system. That is a false positive. The vast majority of denials by the NICS system is a false positive.
Why? Because criminals are THAT stupid usually. They know they can't buy guns legally and so don't bother to try.
ivwshane
33,525
17,031
Yes do the math. 75k/6 million equals what? .0125% that seems pretty fucking accurate doesn't it?
ivwshane
33,525
17,031
Obviously...he's confusing "accuracy rate" with "denial rate" or just assumes that all the denials were valid...sad, sad place to argue from
Did you read the post I quoted that I responded to? Obviously you didn't because the poster made no comment about accurate denial rates.
But I wouldn't expect an idiot like you to understand that.
HumblePie
14,665
440
Back pedaling much? No one cares much about non-denials from the NICS. Who cares if a law-abiding citizen that is seeking to purchase a gun is able to do so without being stopped?
corwin
8,644
9
Wow you are dense...I read them all and you are absolutely clueless as usual.
Reading comprehension isn't your strong point eh?
HumblePie
14,665
440
Yes you should both go back to school. Do they still teach reading comprehension?
Tell me, what is the point to a background check???
Is it to vet people being law abiding citizens? Or is it to stop people who are not legally allowed to own firearms from purchasing them?
If you answer the former and not the later you are a dumb ass.
HumblePie
14,665
440
ivwshane
33,525
17,031
Yes you are back peddling as I responded to exactly what the poster wrote, if he meant something else then he should have wrote that instead.
Sorry I don't speak "idiot speak" like you so I can only go by what people wrote.
HumblePie
14,665
440
dude, you didn't even respond correctly to the post you were initially responding to with the accuracy bullshit.
Here is an analogy of your fucking side of the argument. A net is built to catch fish. I am arguing how good that net is at catching fish by counting the amount it actually catches. You are trying to argue by the amount it does not catch. You are fucking INSANE!
corwin
8,644
9
Lol
Keep trying.
Seriously? The post you were responding to:
Your absolute stupidity in bold
