mugs
- Apr 29, 2003
- 48,920
- 46
- 91
Originally posted by: SarcasticDwarf
The self checkouts are usually *decent* if you only have an item or two, but anything else is a pain in the arse. They have an estimated weight of each item and requires you to do stupid things. Some of them have a bagging area at the end. You have to place each item on there **AFTER** you have already scanned it. Now, it you have a bunch of bulky items (such as TP), this can require you to make a large mound.
That's how it typically works at stores like Home Depot, but at the grocery stores around here that have them (Weis in particular) there's a belt with a sensor that checks each item as it passes under. When the bagging area gets too full, it tells you to bag some of your items. I didn't have to screw it up more than once to realize that if you scan an item before the previous item passes under the sensor, it makes you rescan both items.
Edit: (The ones at the Giant I used to go to on the way home from work had it the way you describe)
I use self checkout lanes all the time, rarely have a problem.
