daw123
- Aug 30, 2008
- 2,593
- 0
- 0
Originally posted by: BTRY B 529th FA BN
There is a puny little 3.5" drive bay at the bottom where i've always kept my drives which has 2 80 cooling fans but, man this is going to be a TIGHT squeeze. I'll probably have tubing running parralel to each other. See on the right side where my res is. I'm going to have to run the rad outlet tube to the side port (top) then my outlet from the res will be the lower side port which sucks for adding pressure which a res is intended to dobut i'll use the top port for my fill port which is what I meant earlier....
So, what do you think of the pump pulling the water out of the block instead of pushing water into the block? It's not a high pressure setup so I'm thinking it might be do-able; also gonna have alot of 90's to make the pump to rad then rad out to res , work.
I'm not sure if it matters where the pump is located in the loop. I vaguely remember speaking to my dad about this (he's a chartered controls engineer) and when I showed him a schematic of my proposed loop, he pointed and said the pump can go here, here or here.
