Anyone else have Battlefield 1 and Ryzen they can test?
I haven't tested many games yet, GTAV seems to be fine. I was checking out Battlefield 1 this morning and immediately noticed an issue with audio. The music was stopping then starting again over and over. In an actual game I could tell the effects sounds were cutting out all the time as well.
I was running my 1700 at 3.8Ghz and 1.35v so as a test I removed any OC and running Battlefield at stock clocks/volts the audio was perfectly fine. Playing with OC I found that even a slight 100Mhz increase with even no voltage increase caused the audio to have issues. No idea if this is a problem with BF and Ryzen, motherboard and OC causing timing issues, bug with slightly newer Realtek?
My specs:
Ryzen 1700
ASUS Prime X370-Pro
Realtek S1220A audio
Corsair LPX @ 2133
Updates so far:
Reported failed on CH6 motherboard as well
Reported failed with ASUS Strix dedicated sound card + Ryzen OC
Reported failed on MSI and ASRock motherboards
Update:
Submitted to EA answers community
http://answers.ea.com/t5/Bug-Reports/Audio-cutout-issue-with-Ryzen-overclock/td-p/5963549
My specs:
Ryzen 1700
ASUS Prime X370-Pro
Corsair LPX @ 2133
Updates so far:
Update:
