mjdupuis
New Build, (preorderd):
Ryzen 2600X
Asus ROG Strix X470-I
G. Skill Trident Z 3200 cas14 2x8GB
Fractal Define Nano S
Moving from previous build:
Seasonic X-650 K3
Corsair MP500 NVME boot drive
Asus Strix GTX 980
What ITX cooler would you recommend? I may be trying an OC eventually but won't be trying to push the absolute limits, probably just an all core clock of 4 to 4.1 or so. I'll be more concerned about noise than anything else, but it's a windowed case so looks are important.
I've looked into the Noctua NH-C14S and Dark Rock TF. I love Noctua but am not excited about having to replace the ugly brown fan for one of their darker fans (add $25 for a Chromax to the $75 cost). The Dark Rock is better looking, and $85, but every review seems to mention be quiet's mounting not being the best. These seem beefy enough to handle some good OCs in an ITX system, but I'm sure I can get away with something smaller. Any other options I should consider?
Priorities would be noise and then aesthetics.
Ryzen 2600X
Seasonic X-650 K3
Asus Strix GTX 980
