Question Ryzen 5k series for gaming, 1 chiplet or 2?
Nov 26, 2005
15,194
403
"The single core chiplet has some small benefits over a dual chiplet design where some cross-CPU communication is needed, and that comes across in some of our very CPU-limited gaming benchmarks."
What benefits are gained with 1 chiplet VS 2 chiplets? Is it lower latency?
Hitman928
6,749
12,477
Hardware Unboxed /Techspot also reported this:
In terms of temperatures, we ran a quick comparison between the Ryzen 7 3800X and 5800X tested in a 21C room using Corsair's iCUE H150i AIO, MSI X570 Godlike, installed inside the Corsair Obsidian 500D. We saw the 5800X running 3 to 5 degrees hotter than the 3800X, which is pretty good given it’s clocking just over 400 MHz higher at a similar voltage.
Seems like they saw reasonable temps on their 5800x as well.
Guru3d also reporting reasonable temps on their 5800x sample.
Hitman928
6,749
12,477
You wanna argue that? Seriously?
PCMag also wrote this. :rolleyes:
There's a huge difference between misunderstanding how the cores inside the CPU are configured and reading a temp sensor and as I've already pointed out, there are multiple outlets that reviewed the 5800x that showed reasonable temps and not the 80 C - 90 C temps being reported elsewhere.
lobz
2,057
2,856
I'm not sure he disagreed with you on this one :)
thesmokingman
2,302
231
My guess would be a losing silicon lottery ticket, or bad bios settings.
Definitely not in a 5800x.
You all are missing it. Look at the 5800x label, its a 105w TDP chip, that's the same as a 5900x and 5950x. Thus per core the 5800x will be running a lot harder than ANY OTHER CHIP in the line up. That's the whole FREAKING POINT of getting a 5800x. The 5800x is the maxim of the Ryzen lineup, not hindered by TDP limits like the 5950x/5900x and it has maximized core layout. It's 105w TDP or 140w real world draw is there for only 8 cores to boost. It seems to me that ppl are just being dumb or obtuse and ignoring what's right in front of them.
scineram
376
295
Good point about heat density. I suppose a 5950X with one CCD fully pegged would show the same thing. But not a natural load.
Hitman928
6,749
12,477
You can disable a CCD on a 5950x and test this theory, if anyone has access to one.
DisEnchantment
1,779
6,798
I have a 5950X, and you can absolutely disable 1 CCD, or even disable the cores of a single CCD.
Looking around for the 5800X reviews I can tell you 5950X has the best chiplets. When running with one CCD my temperatures are nowhere near what I see people on reddit reporting for 5800X or from reviews of 5800X. The max I have ever seen the temperature on my 5950X is 69 degrees, granted I have a 280mm AIO, and it is winter where I live with ambient at 18-20 degrees C (inside the house of course with the heating turned on).
Also 5800X boost around 4.85 GHz. 5950X with 1 CCD always hover around 5.05 GHz at lower temperature.
Hitman928
6,749
12,477
Thank you, that also correlates with what several other reviewers saw in that their 5800x did not show significantly higher temps compared to their 5900x/5950x. It's very possible that there are motherboard issues where the 5800x is getting way too many volts or that there was a bad assembly batch where the solder or IHS placement was messed up. If I were a 5800x owner having high temp issues, I would absolutely check my voltage and frequencies at full load and if those were at expected levels, then I'd be contacting AMD about getting a replacement 5800x (double checking my cooling mount and such first of course).
Nov 26, 2005
15,194
403
I think that settles my purchase decision.. I've been thinking about going all in with this final AM4 cpu purchase and it's looking like the 5950X will be the one.
For now, if I can just figure out why my cores are not boosting beyond 4GHz when gaming that might help me save time until the Crosshair VIII Hero Dark comes out and I can drop this 3800X in it.
EDIT: CB20 MT all cores only up to 4.15GHz,, oof, sigh, PPT 75%, CPU Power ~ 84%, temps 74*C
