Ryzen 3 / Bristol Ridge AM4 owners thread
VirtualLarry
56,587
10,225
But the Athlon 950 has nearly a 50-point higher single-thread score than Ryzen 3 1200. I think this is a toss-up for sure. Neither one is faster than another.
Are you talking about Passmark, CPU-Z, or GeekBench?
Passmark's results are literally useless, as they lump all of the overclocked benchmarks in with the stock ones.
Edit: Unless you're talking about a Passmark benchmark that you've run yourself, rather than the amalgamated results as shown on their web site.
VirtualLarry
56,587
10,225
The A10-9700 at $76 (Same CPU as Athlon X4 950 + R7 iGPU) on newegg is good replacement for the Athlon X4 640 + GT610 for every day use and light gaming.
Oh, and not sure which Newegg site you're looking at, but newegg.com, and Newegg's ebay store, both list the A10-9700 at $89.99. If it were only $6 more than the A8-9600, it would be a no-brainer, but an additional $20? For what, a few hundred more Mhz, and maybe some GPU clusters? For non-gaming purposes, and seeing how it's easy to overclock Bristol Ridge (supposedly, according to some YouTube vids) with a B350 motherboard (at least Asus can), then it seemed a better value to stick to the $70 USD A8-9600, and spend the extra few dollars to get a B350 board, over an A320. Plus, that leaves the window open, to buying a proper Ryzen CPU and dropping it in and overclocking it, although, that would mean getting a video card too. Or waiting until Raven Ridge release.
Anyways, I did it. I didn't quite have the money, but I ordered an A8-9600 for $70, an Asus B350 board with the full complement of video outputs, for $60 (Newegg sale), and a FireCuda 2.5" SSHD, which Newegg had on sale for $55 until the end of today.
https://youtu.be/JoqO-JkmlnQ
Edit: Seems I didn't have to do that. JayzTwoCents did a comparison video between an AM4 (Athlon X4 950, and Ryzen 3 1200) and Socket 1151 (G4560) build, and they were all close, but the two guests he brought on, both preferred the G4560 by a hair. The G4560 build also edged out both others in benchmarks, but was also more expensive.
I wish that he would have tried manually overclocking the AMD rigs, and had used a B350 board, instead of an A320. (Intel bias? I hope not.) I mean, the G4560 doesn't overclock, but the AMD platforms do... if you spend the extra $10 on a B350 motherboard, rather than an A320.
I think that the games that he tried, may have been a tad GPU-limited as well, with the GTX1050 2GB cards he used in both of them. After all, according to the HardwareUnboxed videos on the G4560, that CPU has enough grunt to scale all the way up to the GTX1070 or even GTX1080 territory.
kwalkingcraze
278
25
51
To unswer your question, i wouldnt go to FX6300 from Phenom II 4.3GHz but i would easily go to FX8350 and OC to 4.6GHz or higher.
I'm only allowed to buy CPUs valued at $15 or less, per my strict policy. FX-8350 will never get there, only FX-6300. I work hard constantly each day finding the fastest CPU for less than $15. Phenom 570 overclocked at 4.3GHz and A6-5400K overclocked at 4.9GHz are my top 2 picks so far. An A6-5400K at 4.9GHz has a higher single-thread score than your FX-8350 at 4.6GHz.
SPBHM
5,071
430
how much faster is the X4 950 compared to the X4 880K? because an old school core 2 quad 3.2GHz is faster for current games
http://www.hardware.fr/articles/965-3/performances-jeux-3d.html
r3 1200 is bellow the i5 2500 for games and a little ahead for applications, not to bad, but I don't see it as very exciting given the $100+ price still and over 6.5 years time gap, still I think it's nice that you can OC it, and the same as the 950 it's nice that you can hopefully upgrade to some newer Ryzen revision later on, I'm looking forward to some single CCX Ryzen, even the APU (as long as they don't remove the l3 again).
but honestly I would just go for the g4560 (well if it still exits for the correct price) and save some $, if I really wanted more than g4560 level, R5 1600 is the tempting one.
AtenRa
14,003
3,362
A10-9700 on newegg.com at $75,99
https://www.newegg.com/global/gr/Product/Product.aspx?Item=N82E16819113451
A8-9600 is at $58,99
https://www.newegg.com/global/gr/Product/Product.aspx?Item=N82E16819113453
Athlon X4 950 at $50,99
https://www.newegg.com/global/gr/Product/Product.aspx?Item=N82E16819113456
Well if you dont need the extra iGPU performance of the A10-9700 and you are willing to OC at $59 $69,99 the A8-9600 is the best.
EDIT: hell i just realized those are Euro prices, sorry for that.
You are correct the A8-9600 is at $69,99, the A10-9700 at $89,99 and the Athlon 950 at $59,99
whm1974
9,436
1,571
Ever since Bristol Ridge AM4 desktop CPUs were release I was thinking if it would be worthwhile to build a low cost Linux system around one or go with the G4560? I wonder how much the entry level Raven Ridge CPUs will cost?
AtenRa
14,003
3,362
Im sure there will be sub $100 models of RR APUs, perhaps not day one but a few months later.
Asterox
1,061
1,876
In your opinion, would an Athlon X4 950 be an upgrade for someone with an Athlon II X4 640 3.0Ghz CPU (not overclocked, they're not into overclocking)?
What about a $70 A8-9600 ? Those have some sort of GCN iGPU on them. My friend is currently using a GT610 card, which could probably stand to be replaced with something with newer video-decode hardware support.
Monitor is 1080P. Friend does not PC game (yet - I've sold him a different gaming PC, with G4560, GTX950 2GB, 16GB DDR4, and a 240GB SSD). Yet, he doesn't use it. Not sure why. Probably doesn't want to make the transition from his current Windows 7 64-bit install.
I recently made this comparison, it is only Cinebench R15 but this is more than enough comparison.:cool:
Athlon X4 845 FM2+=Athlon X4 950 AM4
https://forums.anandtech.com/threads/amd-bristol-stoney-ridge-thread.2463487/page-29#post-39044652
A8-9600 GPU(GCN Cores Third Generation or 3.0)
, you can look at the details just click on that link below. I also did a comparison, A8-9600 GPU vs AMD old-new GPU-s in that price range.
https://forums.anandtech.com/threads/amd-bristol-stoney-ridge-thread.2463487/page-31#post-39058654
Reactions: amd6502
VirtualLarry
56,587
10,225
Hmm, I initially overclocked to 3.80Ghz, at 1.350V vcore, before I even installed Windows 10. Well, that has proven to be a stable OC, so I wanted to try for a little more.
I had previously tried to clock to 3.90Ghz at the same 1.350V, but that didn't work out.
So, I tried 3850Mhz @ 1.400V. It booted, IIRC, but was locked at a 15.5 multi, for some strange reason. (I've heard other people complain about this, too.)
So I tried 3900Mhz @ 1.3895V, and that ... sort of worked. It POSTed and booted Win10, ran CPU-Z benchmark, with HWMonitor open. Got to 77C Package temp after five minutes. Thought, that's not so bad, let's try higher. So I selected "Restart"... and it never came back.
I honestly thought that perhaps I fried my Ryzen 3, somehow, because it wasn't responding at all. My AB350M Pro4 board has a "failed boot recovery" mode, whereas, if it fails to POST, it retries three times, then resets to stock settings. This AB350M board evidently doesn't have that feature.
Even after 3-5 manual force power-offs and power-ons, it still wouldn't POST. So I had to pull the video card, and clear CMOS.
Thankfully, after that, and a nail-biting long time, it POSTed.
Long story short, 3900Mhz or 4000Mhz was no-go on my chip, essentially.
So, I'm back at my 3800Mhz @ 1.350V, and it's working great again, and I have had no problems restarting, at these settings.
It's really no surprise, that AMD would stick the "junk silicon" into their lineup at the lowest end, the R3 1200. It does make you wonder, though, if those YouTubers that get a R3 1200, and then, clock it up to 4.1Ghz, if AMD isn't shipping them "Golden Samples". (Edit: Or they were using third-party cooling, and an X370 board.)
Topweasel
5,437
1,659
When it comes to the 1200 you are seeing a combination of two things. One is limited clock potential of the chip. These go to the non-chips. The second defects. This works its way down the list 1600x and lower. Also for the initial launch you could see binning for stock and not capability. Its possible that AMD picked particularly good chips, that wouldn't be surprising, but I doubt they are binning golden samples for the reviewers. They got the best of shipping silicon, but like the rare 1700 4.1 GHz overclock, those will exist for 1200's as well.
Hans Gruber
2,535
1,364
Would you suggest a 1200 or 1300x? Does anybody here have experience OCing both a 1200 and 1300x? Will the OCing results be the same? I notice that AMD includes a cooler in the 1200 now as well that appears to be the same as the cooler in the 1300x.
PG
3,426
44
I have a Ryzen 1200 now thanks to Microcenter and their insane open box deals. They had an open box Ryzen 1200 for $87.96, and I also got an open box Asrock AB350 Pro4 that was $44.96. On top of that they let me have the $30 off bundle deal, so the total out the door was around $114. And then there was a $10 rebate for the board which I sent in already. Even if I don't get that this was a great budget deal.
I'm not pushing it very hard and am only running at 3.6Ghz. According to Ryzen master it's at around 1.225V so temps are low and it's very stable. I'm sure it's good for a bit more but I'm not sure how much and I'm just using the stock cooler so I'm happy for now.
Techspot did a nice test of the Ryzen 3 1200 against some other cpus: https://www.techspot.com/review/1474-ryzen-vs-older-budget-cpus/
The interesting thing is that the Ryzen 5 1400 isn't much better at all for gaming. The SMT doesn't seem to help much, so really for just gaming I don't see a big reason to spend more for the 1400. You probably have to go up to a 1600 to get a significant jump in performance.
Hans Gruber
2,535
1,364
That is actually the same exact setup I was looking at on newegg. Same components. I have a Thermalright Ultra 120 (old but timeless) that has a universal upgrade bracket that works on the AM4 platform though not officially supported by Thermalright for AM4. There is another 3 letter something or other that is higher on the 1300x supposed to be good for another 100mhz if exotic or water cooling is detected by the AMD processor. I see that as pointless because who uses watercooling on a 1200 or 1300x? From what i have read a 212+ will be able to do 3.8-3.9ghz without much effort or problems. I don't want to push voltage above 1.3v. I see it as a waste of power and energy.
VirtualLarry
56,587
10,225
If you really, really, want 4.0 or 4.1Ghz, I would think that you would have a better chance of getting there with a 1300X, since they are (theoretically) binned better / higher, but other than that, I don't think that the stock performance increase is really worth the price increase, seeing as how a 3.80Ghz OC on the 1200 is a no-brainer. (I did my OC out of the blue, before even installing Windows 10).
Just a note, this weekend (hurry, it's Sunday), Newegg has the 1200 in their e-mail blast for $99.99 after promo code EMCRKRJ22 .
VirtualLarry
56,587
10,225
Ok, who's got an A8-9600 besides me, and is overclocking it?
I got mine built, with a 1TB 2.5" 5400RPM FireCuda drive installed.
Well, I overclocked it to 4.0Ghz (40 multi), @ 1.206V + 0.100V offset (don't have a "fixed" option"), and set TDP limit to 65.0W (highest it will go, maybe this should be on "AUTO"? Will it go to 95W on AUTO?).
Still, darn sluggish. CPU load is pretty light, even doing updates. Seems that the bottleneck is the FireCuda, maybe.
Edit: Looks like I managed to just "dial it in". It doesn't want to go any faster. I can POST at 4.3Ghz, AUTO vcore (1.4V+), but it fails to load Windows 10 64-bit properly.
Also, I can't seem to overclock the DDR4-2133 to 2400, even when I push vDIMM from 1.200V to 1.300V.
Ah well, even at a round 4.0Ghz, this things like a slug, kinda. Well, all Bulldozer-derivative CPUs and APUs feel like that to me.
Ryzen 3 and Ryzen 5 are just SO much more "snappy", even without SMT (on Ryzen 3). Overclocking Ryzen was easier, although I kind of alread knew its limits beforehand. Here, I'm vaguely stabbing in the dark. I was hoping for 4.5Ghz @ 1.400V (which is what it gives on AUTO), but apparently not stable enough to load Windows 10.
Edit: After using this PC for a bit, and rebooting it several times and re-starting my apps (getting the SSHD to "learn" my OS boot and programs), and disabling the SuperFetch service (which probably only just confuses the SSHD's learning), and letting Windows 10 do it's thing for a few hours after installation to settle down, it's NOT BAD. (That's at 4.0Ghz. Although, while I'm typing this, CPU-Z displays that the CPU is only running at 1.4Ghz, with occasional higher blips.)
It's probably, roughly G4560 territory, but according to TechSpot's review, the A12-9800, is inferior to the G4560 when paired up with a dGPU. But for desktop tasks, it's OK. I would probably prefer the G4560 though, to be honest. It does seem ever-so-slightly more "snappy". After all, the two CPUs aren't so different, this is a four-core only in marketing-speak, it's really dual-module, just like the G4560 is dual-core, with HyperThreading. Although, I've read that the Excavator arch. removed the "module penalty", so possibly these really are more akin to a quad-core, albeit with much lower IPC than Ryzen or Kaby Lake cores. Oh well.
I haven't really tested the GPU much, except for scrolling, and because I'm not using a dGPU of recent vintage (well, not at all), the onboard iGPU's Radeon 7 graphics, don't support 4K at above 30FPS. So scrolling and mouse movement is choppy regardless.
I am running in dual-channel too. Couldn't seem to overclock the RAM from 2133 to 2400, although I didn't try loosening the timings.
Reactions: Drazick and Schmide
VirtualLarry
56,587
10,225
Well, the entire machine rebooted, when watching a certain 4K YouTube vid. Twice, in fact, at nearly the exact same place, when overclocked to 4.0Ghz.
So, I clocked it back down to stock. Disappointing that even 4.0Ghz wasn't stable. (Could do a RAM test, haven't verified there are no RAM errors.)
Reactions: Drazick
kwalkingcraze
278
25
51
How does your Bristol Ridge compare to $15 A6-5400K overclocked at 4.9GHz? Hmmm... probably no difference, right? There are open-box Gigabyte F2A88XM-D3HP boards as low as $10.50 clearance at my local Micro Center, still no taker.
SirDinadan
108
64
boostclock.com
What kind of board do you have? My board (Gigabyte AB350N-Gaming WIFI) doesn't allow any tweaking - can't set multiplier, ram voltage etc. I only have the A12-9800, but I guess it would be the same with the A8-9600.
I can only achieve 2400 MHz with single rank memory modules. I can't post with dual rank 2400 MHz.
Can you do me a favor and run GTA V built-in benchmark? I experience huge stutters in the last part of the benchmark (fighter chase) and enormous LoD issues.
Insert_Nickname
4,971
1,696
Ideally, anything BD related should be clocked above 4GHz.
The module "penalty" might be removed, but the 2 cores per module still share the front end. Each ALU core is also a fair bit narrower then K8/10/Zen cores, and still share their FPU.
In short, they're more dual-core-with-super-HT then proper quad cores.
Single module BD/PD/SR? Friendly advice, stay away. You will be disappointed... :)
nathanddrews
Graphics Cards, CPU Moderator
Aug 9, 2016
965
534
www.youtube.com
Whoa, any idea what's causing that? Reduced cache pool? Driver maturity?
Polar2002
100
I thought my 1200 was bad when I only got 3.9 ghz at 1.320v. With Ryzen Master I could run 4.0 ghz @ 1.400v. Both with stock cooler.
SPBHM
5,071
430
yes but the main problem is not that, it's just the base single thread performance being a lot lower than average and the lack of l3 is a big problem for games
kwalkingcraze
278
25
51
Does the $15 A6-5400K overclocked at 4.9GHz receive the same single-thread score as the Ryzen 3 1200? Trying to determine its actual number.
