Eh? Come again? 494? That's 247Mhz - DDR494.... You have PC3200 that will 247Mhz @ 6-2-2-2??? Bull_f04k1n_$51t... To my knowledge, such memory doesn't exist.My RAM will do 6-2-2-2 without a problem even when set to 494Mhz.
Originally posted by: Whitedog
OK then... for arguments sake... Let's take the following scenario
Setting 1:
FSB = 150
Mem = 150 (100%) @ 6-2-2-2
MHz = 2100 (150x14)
Setting 2:
FSB = 200
Mem = 150 (75%) @ 6-2-2-2
MHz = 2100 (200x10.5)
Setting 3:
FSB = 200
Mem = 200 (100%) @ 8-3-3-3
My memory won?t do 200 period, so I can?t test this? I?d like to see someone test these settings and post the results.
My guess is #2 will result in most performance. Just a guess.
Cheers :beer:
Originally posted by: pspada
Um, what's with the fsb/memory set to 150Mhz? Wouldn't that be 166? Besides, my CL2 memory is rated at 6-2-2-2 @ 400Mhz. And I don't change those settings when I change the FSB to 247, so it's booting with these settings at 494Mhz. Of course Winblows won't load or run at that speed, but I know that my AGP and PCI buses crap out when overclocked much, so I don't believe these is any problem, even at that speed, with the memory, or possibly even the CPU.
But I'm willing to try it on a NF2 mobo, if you'd like to lend me one..... 😎
Then crank down the MultX. Instead of 10.5x200 and 14x150, do 9x200 and 12x150. Both will give you 1800MHz. Do all the rest of the settings as stated. Should result the same.Originally posted by: Jeff7181
Setting 1:
FSB = 150
MHz = 2100 (150x14)
Setting 2:
FSB = 200
Setting 3:
FSB = 200
Cheers :beer:
I'd test it, but I don't have multipliers above 12.5 available.
You can do it however you want. I was just using 150/200 as a good spread. I don't know what kind of mobo you've got, but the A7N8X will allow you to pick whatever speed you want in 1MHz inc's from 133-250 or something like that.Um, what's with the fsb/memory set to 150Mhz? Wouldn't that be 166?
Originally posted by: jjyiz28
Originally posted by: amoralist
for programs that don't use 100% of cpu, sync is faster than async. that is 220/166 isn't any faster than 166/166.
in fact 166/166 is faster... that is if you are not doing winrar or divx encoding (but are more concerned with
boot up times and program startup) then sync with slower proc is better...
what program doesn't use 100 percent of your cpu?? don't they all ? if not, there would be no performace gain going from a 300mhz cpu to 500 mhz cpu (hypothetical) which wouldn't make sense
Dude, that was really really sad...
You're like, an angry person or something... chill dude.Originally posted by: jjyiz28
what the hell are you talking about?? you contribute nothing to this thread 'cept this?? what's sad?? enlighten me
This is Great!! The kind of stuff we need to see... It just proves to me how worthless synthetic bench marks can be. From now on, I'm going to just test performance where it REALLY counts... GAMES!Originally posted by: Jeff7181
I think PCMark pretty much just cares about memory bandwidth... maybe Sandra would provide a more accurate depiction. However, my 3DMark score was higher too with the 200 Mhz RAM setting... and that's all I really care about, game performance.
I neglected to mention that I also tested the FPS in Soldier of Fortune 2 with 4XAA and 4XAF. I saved the game at a point with a couple light sources in view, and rain, and here's the results...
220x10=2200 Mhz - RAM = 75% (166 Mhz) @ 5-2-2-2 (lowest stable)
FPS = 35
200x11=2200 Mhz RAM = 100% (200 Mhz) @ 7-3-3-2.5 (lowest stable)
FPS = 42
220x10=2200 Mhz RAM = 75% (166 Mhz) @ 7-3-3-2.5
FPS = 34
i think its your fsb/memory ratio that determines what speed you run you ddr400 ram. look in your bios.
whitedog, in my opinion i think #3 will result in better performance for most of the benchmarks. of course, this is just a guess. i too would like to see the results for #2 vs. #3.
I think he was referring to your knowlege of programs and you making such a bold statement about them. NO, FEW programs utilize 100% of the CPU. Most programs sit idle 99.9999% of the time. Look at your task manager. Sure, when they are executing code the CPU is in work, but then not always the processor is being used 100%.
People shouldn't really comment about stuff they don't even know what they are talking about really... and this thread is FULL of such comments. But that's what makes AT forums so unique. 😛 Quite a comical place sometimes. 😉
FPS = 35
FPS = 42
FPS = 34
Thanks Jeff. I'll be setting my system to run sync this evening. I'm SURE there are instances where the faster FSB would be better, but who cares. Games is what we tweak for anyway, and if running sync makes my games run better, than so be it.
FPS = 35
FPS = 42
FPS = 34
Yes... in my origional post, I was saying that sometimes the speed of a person's RAM prevents them from overclocking the CPU more, in which case it is better to run the RAM a-sync in order to attain a higher CPU overclock which makes up for the RAM running out of sync. But if your RAM can keep up, by all means, run it in sync.
Ah so! Jeff, you left out an interesting test question: what if you run the processor at 166, and run the memory at 200? What (crummy synthetic) benchmark and (good real world) game performance would you get in comparison with these current test scores?
And this then poses another question - is game performance enhanced by the extra cache of the Barton chips over the actual default clockspeed of (for example) a 2600+? How about when both chips are running at the same clockspeed?
I wish you were in San Diego and we could try this with my ram.... :sun:
I can see running the RAM @ 166 and the FSB @ 200 ('cause your RAM may not be fast enough to run @ 200), but I certainly don't see the point in running the FSB @ 166 with the RAM @ 200? I don't know why he even suggested doing that? 😕 There's no point to that.
