Jeff7181
Lately I hear a lot of people saying running your memory a-sync hurts performance, and I agree with that half the time. I agree that running your memory faster than your FSB is pointless because Athlons don't need that extra memory bandwidth. However... if you can't increase your multiplier past 12.5, and you have PC2700 RAM... if you want to overclock much, running a-sync is your only option to get that extra clock speed.
While running in sync provides better performance at equal clock speeds, a 2.2 Ghz Athlon XP with a 220 Mhz FSB, and 166 Mhz RAM will perform better than a 2.0 Ghz Athlon XP with a 166 Mhz FSB and 166 Mhz RAM.
The Athlon XP isn't starved for memory bandwidth like the P4 is, so I see no problem running things a-sync in order to achieve a higher clock speed.
I've tested this myself... and even at similar clock speeds, the faster FSB provides better performance than keeping it in sync with the memory.
Of course, if you are able to run things in sync, you should do it, but if you're stuck with slower RAM that doesn't overclock, running a-sync is your only option, and in my opinion and experience, it's not as detrimental to performance as some people have been eluding to.
