I simply don't believe anyone has those three gpus in hand, or if they did they wouldn't publish them anonymously to some random place which cloudfire won't even link to.
100% agreed with this. Doesn't add up
Need? No, you can have custom air cooling that works just fine for that. But a reference blower? Hardly fine, on Titan Black even the impressive NV blower struggles to keep it cool and its definitely not quiet. It'll also leave little noise/thermal room for OCs.
Seeing the awesome performance of the R295X2 cooler would have given AMD a lot of incentive to go water as reference, particularly since Asetek (Cooler Master modified) supplies them quite cheap en-mass.
AMD copped major flak for the horrible reference cooler performance for many generations now. It really IS time for them to fix that.
ps. The pricetag alone would scare away 90% of buyers. ;P The remaining 10% who can actually afford premium enthusiast GPUs, I doubt they would worry about a 120mm radiator.
But a 289W Fiji XT wouldnt need a hybrid cooling solution that would scare 90% of the buyers away.
Everything from power usage to performance of all existing cards is remarkably accurate. 980 leading 290X by 8% at 4K, 295X2 beating 970 SLI at 4K, 290 beating Titan, 280X beating 770 -- essentially a mirror image of TechPowerUp. The delta between 980 and 290X as well as between 290X and 970 is very close to what peofessional sites like ComputerBase, TPU have.
Looks like if these venches are true, those who skipped the mid-range $550-600 980 will be truly rewarded ....really soon! If I had 980(s) right now I would be getting to sell them in a matter of months before losing a ton of resale value. Competition FTW!
Except for the fact that the performance charts show the new cards performing better at 4k than at 2560x1600... I have yet to see that ever be the case in any video card. At worst, the card would perform the same at 2560x1600 as it does at 4k, but not better at 4k than a lower resolution. And the numbers for the other cards look a little funny as well given we know that 4k hammers even current gen Nvidia cards to the point that it wouldn't be a 5% performance penalty as seen with the 780TI, or a 2% penalty as seen with the 980.
The power chart looks like everyone expects it to look like, which means it could be real, or completely fake, and given how fishy the 4K vs 1600 resolution performance numbers are, I have a hard time believing they are true either.
For 6 months since the rumour of the AIO CLC started, you have still not understood what the point of it is. You continue to make this wrong assumption:
*textwall removed*
AIO is superiour cooling but its unwanted by the 90(99)% crowd.
Then you can type page up and page down about the benefits and whatever else. But if it all was that great all OEMs wouldnt use anything else.
Its you not understanding the concept outside the enthutiasts of this forum. And even here you get substantial amount of people not wanting water cooling.
Firstly, where are you getting this 90(99%) figure? It's utterly ridiculous to come up with random figures out of nowhere.
Secondly, if you're considering spending over $500 for a SINGULAR video card, you obviously know quite a bit about this hobby. Therefor we can safely assume you would be well aware of the benefits.
AMD knows as well as any other that a hybrid cooler is a turn off for the 90% crowd/OEMs.
Its you not understanding the concept outside the enthutiasts of this forum. And even here you get substantial amount of people not wanting water cooling. And those with watercooling may not even want to use this at all. But instead connect it to their existing.
Guess what, AIO CLC is even better than that! You seem to have a huge problem with superior GPU cooling solutions if they're provided by AMD. I am not taking the bait.....
How many OEMs do you know that will fit or offer water cooling? Just look what you can get with a 295X2.
What happens if you already got water cooling?
*textwall*
A lot of them do I'm sure AIO cpu coolers are pretty big nowadays aren't they? A 295x2 is also a very different situation as it is a multi-gpu card, which would turn off some customers, and then it's water-cooled, which I admit would turn off some customers as well, so you're using a situation where it has a two things going against it. I don't think that's a good comparison.
And lastly you compare a blower card to an open card? /facepalm
I dont care what a better card than my GTX980 gives or whatever it cost. I dont know why its such a big deal for you. Seems your entire world evolves around that.
If watercooling is so great. Why isnt it used everywhere? Or perhaps because it got disadvantages as well?
He was saying that enthusiasts do indeed look at options
The downsides of AIO GPU cooling? I can think of a few:
1. When logic fails and you fall victim to scaremongering (ooo, what if it leaks?!!)..
2. It looks uglier, its hard to make them aesthetically appealing due to the tubes. Custom water loops have fancy tubes & lighting, AIO do not.
3. It may not fit some cases if user already has AIO for CPU cooling. Due to a lack of additional 120mm radiator space.
Let's settle that argument, shall we? We of this forum aren't representative of the entire buying population but I'd like to think we are representative of people willing to pay for top end GPU stuff. I'll be the first to say if those leaks end up being true and 390X is ~$650 with AIO CLC, I would buy that at launch. So who's with me? And who here would say they would definitely NOT buy that?
You forgot one little tidbit. :sneaky:
Are you referring to different than AIO cpu coolers or gpu coolers? if it's cpu coolers, then you have to take in to account that it is a MULTI-GPU ( caps to highlight the major difference between the two) card.The 295X2 isnt really that different. If the OEMs doesnt give it as an option in the selections or only very limited. Then you have to ask yourself why.
The greater perspective is lost when the only focus in water cooling temperatures and such.
Already there you limited the amount of people to a niche.
What about the pump?
And it may not even fit cases that doesnt have any other AIO.
