Actually, the dealer once told me the safest best in roullete is to bet 1-18, which has a 1-1 payoff and bet the 3rd 12 (which has a 2-1 payoff). Bet the same amounts on both bets and you've covered all the numbers on the table except the zeroes and 19-24. If you hit the numbers between 1-18, you break even and if you hit the 3rd 12, which is 25-36, you win the amount you bet since the payoff is 2-1 and you only lost the amount you bet on 1-18. You can of course, bet the other way around too and bet the 1st 12 and then 19-36. which would leave only 13-18 uncovered by your bets. Obviously, the dealer still has the edge because of 0 and 00 and the numbers not covered in the middle but your odds of losing are the lowest under this betting method. I've tried it myself and came away up nearly a thousand dollars betting $40 per round. By my rough count, I was able to break even or come out on top 5 out of six times. It took me all afternoon at the table to win the amount I did and for those seeking instant gratification, this isn't the way to go but if you want to play it safe, I don't know if there is anything safer than this method.
