Originally posted by: Googer
Originally posted by: TimJ
Joe Schmoe broke his ____. He was like "damn, there goes $X down the drain." He reads your thread and thinks "wow, if those RMA departments are really that stupid, I'll just RMA it and get a new one."Originally posted by: Googer
If anything it will inspire more people to RMA stuff they broke.Originally posted by: mechBgon
Number of RMA abusers who will cease their abuse as a result of this thread?
Please explain your reasoning. Thanks.
It is a concious decision to RMA somthing, you cannot stop some one born with out a set of morals from doing the wrong thing.
Your answer is like telling a terroist that bombs scare people. Its nothing that they dont already know.
It can be spelled either way.Originally posted by: Mrvile
It's actually whiskey.
Thank you.
When I was talking about the B&M story, I was merely making a comment on pricing, I was NOT referring to price markups due to RMAs. I understand full well the markup is for B&M and online stores as well, which is why in my first post I referred to the item price without specifying where it was bought at. Give me some credit here. I've already taken a couple economics classes, and they never covered anything that had to do with returned merchandise markup. I'm not going to spend hundreds of dollars to take a class just so you can get me to believe your statement. Give me a reliable article on this and it will save us both the trouble.
Originally posted by: Dethfrumbelo
There are plenty of signs out there that lead one to believe that the world is coming to an end. This is not one of them.
Originally posted by: piasabird
If you send a motherboard back put some mark on it so you know it when they just mail it back to you claimning it is a new motherboard.
So you know that they aren't sending you the same board back claiming that it's new. Recording the revision and serial number also works in this situation.Originally posted by: Googer
What do you mean?
Originally posted by: jayn
whisky
What do you mean?
I dont know for sure, but I think you may not understand somethning here. RMA's Cost the Vendor (manufacturer) money and he passes that on to the retailer. RMA's dont affect the bottom line of a retailer as much as the vendor of that product. Get the whole notion of it costing the retailer (company) that you purchased it from, because in MOST cases it does not. I repeat, again it costs the maker of the product money and therefore makes it more expensive for the next guy to buy one no matter where he chooses to get one from.
Has Newegg stated anywhere that "RMA abuse" is the reason that they no longer direct-RMA motherboards? Link please. Newegg has been selectively not RMA'ing certain models of motherboards since nForce2 came out, as I recall (edit: before, actually, starting with the EPoX 8KHA-series and their high CPU-temp readings). It may be that they don't want to deal with RMAs period, legit or abused.
I'm not sure I blame them, really... for example, 90nm Athlon64's require BIOS updates on popular motherboards to run, or to run properly (depending on the board). Similar thing with Prescott-core P4's on many Intel boards, even Intel-branded boards. People make a best effort, can't get it to run, and conclude in all sincerity that the new mobo is most likely defective. It isn't working, at any rate, and so they've never had the chance to abuse it. Back to Newegg it goes. Why is it Newegg's fault? Should they open every motherboard box and update the BIOS before sending it? Then we'd have people freaking out that they got a "used" motherboard 😕 "IT WAS OPENED, I CAN TELL!!!"
Based on my observations here, this "it-has-never-worked" RMA appears much more prevelant with the consumers than "RMA abuse" in the realm of motherboards. Now, CPUs might be a different story... people sometimes say they're RMA'ing their new OC-special CPU because their OC was not meeting their expectations.
Originally posted by: klah
All hardware should have an integrated PROM that writes a bit when it has been overclocked >10%.
How about all of those LGA775 motherboards with bent pins, I have heard about Motherboard manufacturers screaming about need-less RMA's on those.
Have you ever read some of the reviews on newegg, people admit to abusing motherboards, and dont deny that it does not happen. I have buddies who work in retail and I know very well what happens.
This Topic in this forum is about RMA and Hardware abuse in general, it pertains to hardware of all spicies. Not motherboards and Retailers exclusively (newegg.com was not on my mind's radar when I wrote this).
By the way newegg is not always the cheapest or the best like some may have you believe, only a fool would buy something with out shopping around. But this is off topic, so lets not dwell on that too much here.
