Originally posted by: Ornery
If the OP comes back, I'd recommend he listen to Jon. He doesn't sound like one who has been sucked into the hype, like so many here.
I got my first dose of reality about 25 years ago. A jaded salesman at a "sonic emporium" type place had me listen to two different receivers plugged into the same speakers. He switched from one to the other, and asked what difference I heard. I told him the truth, that I couldn't hear a difference. He told me that the one receiver was $150.00 and the other was $1,500. He asked, "Why pay that difference, when they both sound the same?" Beats me! Didn't need a receiver at the time, but I purchased a set of KLH speakers from him, and they're still in use at my in-laws today.
Put the money into some decent speakers, even if they're only bookshelf sized. When you move into a house, they can be moved to the den, or bedroom or something. The speakers are the weak link in any system. To test the quality of the sound, listen to a recording of a naked acoustic piano and hear which speakers sound most realistic. Buy the cheapest ones that meet that goal to your satisfaction.
Originally posted by: Falloutboy
go with a Panny XR50 receaver as for speakers i'm not sure.
I went with some Radioshack LX-10 Mains, CS-5 Center, and CS-5's on thier side for rear sorounds unfortionatly non of these speakers are made anymore and if your find them thier too expensive now to be worth it. I got all these speakers for a 100 bucks from my boss when I worked at radioshack.
Case in point regarding budget. If anything, I'd recommend some sort of Denon/Yamaha/Onkyo/Harmon Kardon receiver because they accurately reflect continuous wattage. The panasonic/sony/etc receivers claim "200 watts!" but that's maximum output, and the actual wattage could be anywhere in that range. If you're not an audiophile just keep in mind higher CONTINUOUS wattage = better.
In terms of speakers well...you get what you pay for. Just avoid Bose.
umm go to avsforum.com to check out the XR-50 very highly rated receaver. also the plus with the XR-50 is its a digital receaver so if your using a digital source it never needs to be converted to analog which helps alot. granted its actual RMS watts are around 35watts but be honest with your self 5 clean watts is all most people ever need, and will drive most effecient speakers well over 100db
5 clean watts? Are you kidding me? There's a reason people buy the 130W (continuous) Yamaha and Denon receivers. I personally have a HT set of Klipsch Reference 35's and my $500 Onkyo receiver at 70W/channel maxes out at a decent level in Surround mode, but it's obvious they could go so much higher and cleaner. And this is with extremely efficient horn speakers. Granted they are 8ohm speakers, so the wattage will go up with lesser quality, but a 5 watt source definitely will not cut it.
Given my experiences there is no way I'd recommend anything below 70W/channel continuous if you're buying at least decent speakers.
I think we've been syringered by the OP though.
its because the onkyo you have deffinately does not put out 70w. it probably puts out 70 watts to a resistor possibly. ever manufacturer has a different way of testing the receivers capabilities. a nice quality 30 watt amp (tube, or normaly) will power speakers, but it depends on the size of the room.
MIKE
MIKE
I'm not sure what you mean, unless this is EE related. Here is the manual for my receiver, it specifically states 70W continuous to all 5 channels.
Ironically enough I checked the fs/t page where I bought this and Falloutboy PMed the seller after I'd already bought it. I'm aware manufacturers test their hardware differently but the quality brands, i.e. Harmon Kardon, Onkyo, Denon, etc. are known for accurately testing them. Other more commercial brands such as Panasonic, Sony, Pioneer, etc market their receivers based on the maximum wattage. So just like Falloutboys example, they claim their receiver puts out 200 watts when the actual continuous wattage is roughly 35.
"5 watt source definitely will not cut it..."
He didn't say the source only needs to be 5 watts, but that most people use less power than that. Get your hands on an audio watt meter and hook it up to your system. You'll be surprised to learn that it will be loud enough to make your ears bleed at only a few watts output.
and i'm not saying its a bad receaver its quite good but in my research as of late pannys digital amps seem to be the way to go in the sub 500 dollar catagory and alot of people at avsforum agree with me
This is true, however, to be able to listen at THX reference (real theater levels) levels your gonna need more than 5 watts.
MIKE
I don't know enough about Panasonic to say whether it's quality or not, but why would they advertise such a false statistic like maximum wattage? Thanks but I'll stick to dedicated HT companies rather than commercialized brand names.
apac:
basically a speaker will state that it is a 4 ohm nominal load. which means with no other factors, temperature, box, etc. it will show a 4 ohm load. however once you put that speaker in a box, the ohmage the amp sees is different. and if a company tests their quality by using a resistor, then you will only get that power at that resistance specifically and you have no idea how the amp will react to the different loads the speakers can possibly show.
and yea panny has some good reccomendations from what ive seen.
MIKE
every company exagerates on watts in the lowend of the product line, I mean think about it you know nothing about home theater and you are faced with an advertised 100watt per channel KLH amp for 100 bucks sitting next to it is a $500 denon labled at 40watts per channel. the consumer will buy the KLH almost everytime. but in reality the KLH's audio isn't as clean at 5 watts as it is at full blast on the denon. this is why all companies exspecially on the consumer end exagerate watts, because the public thinks if its not over a 100watts its crap. I mean I would think computer geeks exscially would be able to under stand this because of the whole MHZ myth thing intel has tried to pull for years
Yet low end products from companies like Denon still sell great because anyone worth their salt cares nothing for exaggerated wattage. Everything I say applies to someone who has researched technical HT stuff, not some idiot from McDonalds. The only reason to list such a statistic is shady propaganda and marketing technique that helps salesmen screw a customer into buying the product. Based on that fact alone I'll stick with Denon.
Assume a 90db/1W@1m sensitivity. With 5 W, you get about 97dB at 1 meter. Assuming a listening position of 3 meters, you get 87.5dB.Originally posted by: spidey07
umm, 5 watts? Over 100 db?
Think again. In my theater 200+ watts per channel is hardly enough.
It is my opinion that unless you have VERY efficient speakers like horns you need at least 100+ watts per channel to have undistorted reference volume at the listening position.
You can only do so much with 5W. See my post.Originally posted by: Ornery
"...your gonna need more than 5 watts"
No, you're still only going to be using 5 watts, but you'll need an amp "rated" higher. The gear has to be able to keep putting out that 5 watts constantly, cleanly (without clipping), and without burning up components.
Originally posted by: Howard
Assume a 90db/1W@1m sensitivity. With 5 W, you get about 97dB at 1 meter. Assuming a listening position of 3 meters, you get 79dB.Originally posted by: spidey07
That's a pathetic sound level. Of course, that might go up to to 81 or 82dB or so, given that two speakers slightly up the sound pressure, and the room adds a bit.
No, two speakers playing the same sound DO NOT increase SPL by 3dB.Originally posted by: Falloutboy
your math is flawed. two speakers outputing at 97db would be 100db at 1 meter. and the fall off is 3 db for every meter so you would be at 90db at 3 meters without even calculating in room gain which depending on the size of the room could be alot or a little. also add into this a 5.1 setup in that thier would be more than 2 speakers at anyone time outputing sound and as long as you aren't trying to fill a large room you got quite a bit of sound at "only" 5 watts.
