Originally posted by: Pacfanweb
Originally posted by: Slickone
On older non computer controlled engines with high compression ratios in a pinch you can actually get by with using regular and adding a couple pints of diesel fuel to the mix to raise the octaine rating, it smokes like crazy but it works
Wouldn't diesel lower the octane rating? Diesel does have a very low resistance to knock.
No, diesel is MUCH harder to ignite than gas. Diesel does not have a low resistance to knock, considering that most diesels run around 22:1 compression.
Adding diesel to gas would basically raise the octane......just smell most any octane booster, and you'll definitely think it smells like diesel or kerosene.[/quote]Incorrect.
A diesel engine works differently than a gasoline engine. It does not draw the already mixed fuel/air into the engine. It only draws air into the combustion chamber via the intake stroke.
The air is then compressed to the aforementioned ~22:1 compression ratio.
When the diesel fuel is injected, it immediately combusts in the superheated, compressed air.
Diesel is rated by its cetane number, which is the exact opposite of Octane. It measures how
easy the fuel is to spontaneously ignite. The higher the number, the easier. You can actually buy additives for diesel to raise the cetane number, the same way you can buy additives that raise the octane number for gasoline.
So, he is right. Not only would that seriously mess with your fuel system, it does not raise the octane.
