Only if you mean it.Originally posted by: Jeff7181
Ok... you're right, I'm wrong. Satisfied?
Ok... you're right, I'm wrong. Satisfied?![]()
Well, you're still wrong, if that's what you mean. So I guess it doesn't.Originally posted by: Jeff7181
Does it matter?
No, because this isn't about who is right and who is wrong, it is about what is right and what is wrong.Originally posted by: Jeff7181
So are you saying that computer controller cars, considering no problems, always run the perfect mixture, and never run lean or rich?Originally posted by: Zenmervolt
You prove my point. The article deals with a carburetored engine designed for high-RPM operation. Carburetors are notoriously awful at fuel metering. Any modern fuel-injected engine with computer controls will adjust for the gasoline and lean out the mixture if the burn is incomplete.Originally posted by: Slickone
I didn't say forums are where I got all my info. I know there are many clueless people in forums. Many in this thread (not referring to you).
BTW, calling someone's information bullsh!t is pretty immature. How old are you?
BTW, what happens when you use jet fuel in a piston engine? What happens when you use gasoline in a gas turbine engine?
This isn't an article I've seen before and isn't 'the article' that made my mind up. I don't know who this is. Anyway it says:
As to usability in a motor, ultra-high numbers are questionable. Octane will make up for some sins that an engine builder might have built into the motor, but an engine only needs what it needs... not a bit more.
Also:
TOO MUCH OCTANE CAN BE BAD!
Right now in the racing fuel business, there's a race to market the highest octane fuel that you can make. People relate the highest octane to "my motor is making more power." That couldn't be further from the truth.
One of the downsides to building a fuel with ultra-high octane is adding components that really slow down the flame front in the combustion process. You can get the flame front so slow, that the engine is now running in a too-rich condition. This takes away horsepower. So here you are, slowing down the flame front and getting rid of detonation, at the expense of losing horsepower.
BTW, that's "harm".
I never said that it could not cause problems, I said that if a stoichiometric mixture is maintained it cannot cause problems. That assumes that there is an adjustment to the mixture in order to maintain complete burn. If the engine is running rich, it's running rich and that's the problem. Regardless of whether the fuel is causing the rich condition or not, it's the rich condition and not the fuel that is causing the carbon deposits. Again, in modern, computer-controlled engines with fuel injection the mixture is adjusted and there is no problem with deposit formation. This assumes that all componants (especially the oxygen sensor) are functioning properly.
I've had my opinions called bullsh!t by my best friends, my worst enemies, people twice my age, people half my age, people I know, and people I don't know. If someone calling your information bullsh!t is offensive to you, I suggest that you grow a thicker skin because you're going to be offended a hell of a lot in this world unless you learn that not every colloquial use of swearing is a personal attack. As for my age, old enough to know what's right and young enough not to choose it.
ZV
Even at 14.7:1 it's possible for the burn to be incomplete on a molecular level.Originally posted by: Slickone
Also:
BTW, that's "harm".
ZV
I was thinking about the article I linked after I posted and wished I hadn't. I can't find all my old links to articles on the subject.
Calling me bullsh!t doesn't offend me.
Pacfanweb, does Saleen remove the knock sensor?
Remember the GM manual could be wrong. Humans write manuals, often containing mistakes. And that's not really something that would be contested by a mechanic and corrected, since repairing a problem is never going to rely on knowing whether the ECM can advance to take advantage of octane ratings higher than specified by GM.
Nope. But they recalibrate the ignition advance curve to where the timing stays pretty much near full advance all the time, so even if the PCM wanted to, it can't lower the timing enough to not spark knock on lower octane fuel.Pacfanweb, does Saleen remove the knock sensor?
1. You're okay using 89. The knock sensor advises the PCM on when to pull back the timing.Originally posted by: Operandi
The manual for my 98 SHO recommends 93 but says lower octanes can be used but performance may decrease. Is it better to run 93 100% of the time?, or am I ok using 89?
Also, I'm not exactly sure about this but I seem to get slightly less mileage using the 93 octane but its pretty negligible difference or perhaps just my imagination?
There is nothing incorrect about this statement.Originally posted by: FrustratedUser
The higher the octane, the less energy the fuel contains.
No
1. You're okay using 89. The knock sensor advises the PCM on when to pull back the timing.Originally posted by: Pacfanweb
<blockquote>Quote
Originally posted by: RobCur
For some who disagree with me, would it make sense to use to most expensive fuel on a V8 engine, guggling up so much gas? it wouldn't help much either cause the engine is already powerful enough as is.. A weak car like my puny truck mazda b2200 of V4, 85 HR PWR benefitly greatly from premium gas then regular or middle grade, plus when I do that, my engine is weak and gets cut off alot. Today's new car is V6, so I recommend it is best to use unleaded plus.
Originally posted by: Nebor
<blockquote>Quote
The reason for 3 different type of gasoline? there 3 different types of engine.
4 cyclinder, small engine need highest quality like supreme/premium
6 cyclinder, unleaded plus
8 cyclinder, regular unleaded
Very simple.
<blockquote>Quote
2. It's your imagination.
3. You will have slightly more power by using 93 because the PCM will advance the timing farther.
Wrong. Using higher octane than required will do not harm to your engine. It will harm your wallet, but not your engine. The only thing that octane does is raise the self-ignition point. A spark plug in any engine operating with a stoichiometric fuel/air mixture (i.e. any modern engine) will ignite the fuel/air mixture for a full burn regardless of the octane level of the fuel and regardless of the engine's octane requirements. Octane prevents self-ignition from compression before the spark plug fires, which is a concern in high-compression engines.Originally posted by: Slickone
<blockquote>Quote
<blockquote>Quote
No advantage, not cleaner, not smoother, not faster (unless your engine needs/can use it). As mentioned, go by your owners manual. It's actually less clean, since it has additives to make it burn slower. Using higher octane when you don't need it can actually do more harm than good by leaving deposits since if your engine doesn't need/can't use it, it isn't fully burned.
funny, how no one seem to know why their are 3 grades? yet you ali,say its different octane level well duh! which is 3 different quality(same thing, worded differently!). all car manual says unleaded fuel, not plus or premium. Its a matter of choice and preferences..
Why use lowest octane on a weak car??? it does not make sense to pay less for a very fuel efficent car like volkswagon etc or any small engine.
this arguement is getting pointless.es.s.s buy whatever you want and say whatever you like.. end of discusssiosns.s
No. It will need to advance the timing with higher octane to maintain the same efficiency, and will probably in reality have better efficiency.Originally posted by: Operandi
Hmm... Alright, but couldn't the advance in timing affect efficiency?
Advancing the timing improves efficiency(not universally, but in the context of this post).[/quote]Originally posted by: Eli
<blockquote>Quote
