I know this is a little off topic, but since this is the place where I found the deal, I figured that others who have gotten in on the deal could help me out...
Hey guys, just a few questions about this monitor... but before I ask here are some things that might make things clearer. Around July I jumped in on this deal after 2 months of looking for monitors. Due to the great replies posted in this thread about this monitor's performance, and quality, I decided to buy one at allthingstech. That monitor is fine. Then just about 2 weeks ago I ordered another one because I needed something to replace an aging 15" crt, and seeing how great the first one was I thought a second one would be just as good. Both were ordered as Grade A, but the second one that I ordered (which also happened to be the last one in stock towards the end of November) seems "less durable" than the first one I got half a year ago. For one, when i turn on my first monitor it makes a smooth low-pitched "power up" sound. The one I bought last month made a louder "booong" power-up sound than the other one... I know this sounds really minor, but the difference is that one sounds like its running fine, while the other sounds like its about to die. Kind of like a car. Another thing is the display as the monitor turns on- The first one looks flawless, the monitor starts out black, takes about 2 seconds to power on then all the colors are displayed at once after it is fully on. The second one seems to be loading certain colors and backgrounds first. After pressing the power switch, the loud "boooong" sound occurs then i would see the green, yellow, or white colors load up first onto the blackscreen before the rest of the picture shows up. This monitor is also noticeably dimmer than my other Grade A. Is the tube dying? or about to die? The way it sounds when it powers on scares me, but other than these noticeable differences, both monitors are currently fully functional... for the time-being.
So my question is to HomerJay and to other customers who has this monitor- Is this normal or am I getting a grandfather monitor that is heading for the grave? And to those who have had their monitors burned out, do these look like familiar symptoms? Some answers would be great, thanks.
Once again I know this sounds more like a tech-support type of thing, but it would be really helpful to know if you guys are experiencing the same things with your Grade A or Grade B's. I really hate the hassle of sending large items back and forth, and items of this weight do not ship cheap. Replies would be really helpful in deciding whether this monitor should go back or not. Thanks again. Sorry for the long post.
