I found the Klipsch for 207 bucks. The Logitech ones are 132.00. Is it worth the difference at all? I read reviews and it seems the concensus is the Pro Media 2.1s are very hard to beat sound quality wise.
Mad: I heard those weren't so good and that you might as well buy the much better Z2300 ones for a bit more $.
