Originally posted by: whatever6750
Also how should o go about tieing my computer into this? Do most receivers have an imput that will work?
There are several ways to hook up to a receiver from a computer.
Stereo analog:
1/8" to dual RCA adapter then run RCA to the receiver.
You'll get stereo for everything coming out of the comptuer. You'll be able to do surround processing like Prologic II etc. on a modern receiver from this to get sound out of all speakers.
Movies and DVDs played from the computer will not be true surround.
5.1 analog:
Three of those adapters above from a 5.1 output on your card to a 5.1 input on the receiver. You'll have to check the receivers before you buy them to see if they have a 5.1 analog input. The Onkyo 780 set for example has that input.
You'll get stereo from music as it should be.
You'll get 5.1 decoded by the soundcard for DVDs.
You'll get 5.1 from games processed by the soundcard.
Standard digital:
You need a soundcard that can output digitally or a motherboard that has that output integrated.
Connect either a digital coaxial cable (a standard video RCA cable will work fine) or a digital optical to your receiver.
Stereo from music.
You'll pass a DD or DTS stream from DVD movies for your receiver to Decode (you'll get the correct 5.1 output)
You'll get stereo from games. You can do surround processing on your receiver to get sound out of all your speakers, but it's not going to be true surround sound.
DDL digital:
There are a couple cards and a couple integrated solutions that can encode DD in real time.
You use the same type of connections as a standard digital connection.
Stereo for music still (that's what you want)
You'll pass DD or DTS to your receiver from DVD movies.
Games will be processed by the sound solution and then encoded into a DD stream. Your receiver will then decode the stream and get you the correct 5.1 output for games.
