Rate My Rig
Could I use my 40 gig ide harddrive to load a os and test overclocking on that? It's an older drive prolly 5400rpm. Would the overclocking compensate for lack of hard drive speed?
I would just unplug the sata while I load up the ide. Ideas? I really like the speed the via sata offers.
Originally posted by: Hacp
Originally posted by: love2skate824
36gb raptor=nono
obviously difference in opinion is great. While you don't recognize the benifits of a fast hard drive, I like the extra snappy feeling it gives.
Hacp,
Don't the 36 raptors have some issues...I would think if your gonna splurge for the raps get the 72's...
any problem with o'c with the raptors?
Yes.
No. But, if you run benchmarks that are not HDD dependent at all (SuperPi comes to mind, as do a number of others), you can minimize the impact of the slow drive. Also, if you first run a benchmark with the slow drive and no overclocking, and then overclock and run the same benchmark, you will still see an improvement in almost all benchmarks.
There's nothing wrong with your proposed solution. And also, the Promise SATA should perform just as fast as the Via. I also recommend listening to theman, since he has the same board as you, and I do not.
