This remote is kewl. It would be nice to have more spaces around all the buttons. There simply all grouped together in one big bunch. Also, it states that when you select a component( tv, vcr, cd, etc.) the buttons which operate that item are highlighted with an individual color. Well the same buttons lite-up no matter which mode i'm in. No biggy really. Making that jp1 interface was easy and it helped alot in getting this thing to work with my equipment. Unlike tons of remotes i've tried, this one actually operates ALL of my equipment. By the way, I made my jp1 interface connector from a sound card audio wire which normally plugs to a cd-rom drive. It had a 4 plug socket at each end, so i simply cut the wire in two, glued both 4 plugs together to make a 8 hole plug, wired (since it had 2 red, black, white wires, I had to make sure I was using the right ones) it up to a 25pin connector and it works. I then made a mark on the remote so I know which way this 8 hole plug connects. This wire is just under a ft long. Very easy job.
