Sorry for the bump, but how you doing mate???? How's your Eyefinity setup treating you?
Hey Wermad, I'm pretty good. :awe:
My eyefinity setup is great. Since I bought the 4k monitor (Samsung U28D590D) as center monitor to replace my third DVI monitor (that I had problems with DVI to DP adapter), I'm having no issues at all. I can play eyefinity at 7680x1440 (8024x1440) with no problem and also beneficiate of the 3840x2160 panel if I want.
I recently moved (last Saturday) and I moved from my condo to a house (finally). I just finished doing my bunker/man cave/desktop and its awsome. Only problem is that my rig is in the basement and the basement only has A SINGLE 15 AMP breaker for the whole level.
Yesterday I started playing Grid Autosport with eyefinity and my Quad 290x and noticed the lights were dimming. My PC room has 5 x 50W lights in it and I noticed on my Kill-A-Watt that my whole setup (including monitors speakers and LEDs lights on walls) was pulling 1500watts and this was with cards at stock and 4930k @ 4.5 Ghz.
Total watts:
Lights: 5 x 50w = 250w
Full PC: 1500watts
This gives 1750watts on a 15 AMP breaker which is 1800watts (@ 120v).
So was playing then... my girlfriend started the central vacuum cleaner and guess watt?
The freakin breaker tripped
:biggrin:
SOOO next mod is add a 20 AMP circuit dedicated for my rig only. I already haver the breaker, the 12 guage wire and the 20 amp wall plug.
Check my new bunker
😀 (Need to paint the house)
________________________________________
And what about you man, still rocking the 7970 Lightning?
