thesmokingman
Drive 10mins to that bestbuy and get that asus 1440 with the native dp port??
Oh, and have you tried calling AMD tech support?
KaRLiTOS I applaud your patience. I would have changed video cards by now.
In that case, dump the setup and move on. Maybe 780ti's will do the trick.He's been in contact with an AMD engineer. I think a while back he mentioned that they might know what's wrong but it might be a while before they "get" to it.
So, now what I did to test.
First, I formated my hard drive to be sure that there is no left overs. First thing I tried is Run my Quad Fire setup on a single DVI monitors
-QuadFire 290x + Single DVI Monitors = PASSED
Then I tried QuadFire 290x on a Single DP adapter monitor
-QuadFire 290x + Single DP adapter monitor = FAILED
So in conslusion of those tests
-every cards are working fine
-motherboard is working fine
-every PCIe slots are fine
-No power issues (also tested each wires of my PSU to verify the stable voltages)
-DVI outputs are fine
So I proceeded to test each single cards individually with the DP adapter monitor
-First Card + DP adapter/monitor = PASSED
-Second Card + DP adapter/monitor = PASSED
-Third card + DP adapter/monitor = PASSED
-Fourth card + DP adapter/monitor = PASSED
So in conclusion to those tests:
-Every cards display port outputs are working just fine
-Every adapters are working fine (the three of them)
-every monitors are working just fine
Then, my next steps were to try every combinations of CrossFire with the DP
I tried :
-Card 1 and 2 (crossfire) + DP = FAILED
-Card 1 and 3 (crossfire) + DP = FAILED
-Card 1 and 4 (crossfire) + DP = FAILED
-Card 2 and 3 (crossfire) + DP = FAILED
-Card 2 and 4 (crossfire) + DP = FAILED
-Card 3 and 4 (crossfire) + DP = FAILED
Between each of these tests, I was reinstalling Windows 8.1 to be sure that there is no crap and was trying different drivers from 13.11 beta 6 to 14.3 beta 1. And sometime trying more than one drivers on a single combination.
Then, my last test, which is one of the most conclusive was to test QuadFire 290x with eyefinity but with the DP monitor unplugged and only the DVIs outputs. So the resolution was 5220x1440 (eyefinity with two 1440p monitors)
QuadFire 290x + Eyefinity Dual 1440p monitors = PASSED
Metro Last Light Benchmark 5220x1440
So my conclusion is the same as 3 months ago
CrossFire (or tri or Quad) doesn't work with the display port outputs
My only way to be 100% sure of that is get some GTX 780ti SLI to test but keep in mind that the same system (exactly the same system) same monitors and same adapters were used with
-Trifire HD 6970
-QuadFire 7970
With no issue
I prefer to upgrade my monitors then doing a sidegrade (downgrade) with some 384 bit bus cards. Nvidia doesn't scale pretty well past 2 cards.
I might get a 34UM95 From LG (3440x1440) and maybe sell one card but I really love my cards and they OC pretty well. They also stay pretty damn cool with EK blocks and backplates. I might keep the four :awe: .
He still has to move on. The engineer AMD recognized the problem and has no solution. It is not going to work for now. It is time to stop banging his head against a wall and make hardware changes. Heck, just go back to 7970's if brand loyalty is a problem. 🙄 (hopefully this is a BF4 thing).he already said no to green cards.
Well, like I mentioned before, and other posters incorrectly answered for you, it may be time to switch cards. If AMD already replied confirming the issue without a fix, I'd stop banging my head against a wall and get a card that does work for your setup. This does not sound like fun.Brand is not a problem. It's not BF4, it's in all 3d applications.
I enjoy tweaking as much as the next guy, but not being able to use your video cards with your monitors is quite another.Quite the opposite. Its what PC is all about. Tweaking, tuning, breaking, fixing....
If you don't like it, consoles may interest you more.
So he is not having issues getting his 3 1440p monitors working with 290x CF? What is the issue?That is not the issue here...
Sorry I havent read the entire thread (on lunch at work) but has anybody suggested a newer video card bios? What brand are these and are they the reference design?
TPU has a nice collection of user uploaded GPU bioses you could try. What version(s) do your cards have?
"PP_PhmUseDummyBackend" as DWORD, value of ‘1’
0000 - First cardHKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000 (0001 , 0002 , 0003)
