Cerb
Originally posted by: mwmorph
Originally posted by: Cerb
If you can pull off a 6800GT fanless, you've got good air flow. The extreme one will be nice and loud. The Schnooner will offer only slightly better temps than the Zalman ZM80, but not by much (and may or may not properly work in a desktop case).
The VF700 is nice because of easy installation and overall good cooling. mwmorph is wrong about it not cooling RAM. I don't know of it fits, though.
None of those large ones will be quick and painless to install--trust me. Good for a 0dBA card, but not easy to put together.
At this point, any of the decent fan-based coolers (except maybe the extreme giant III, which is just insane) should work well. The Silencers are not better or worse than the VF700, and neither are better or worse than the Schnooner, which is not really better or worse than the ZM80D. It all depends on what you want out of it.
really? i mean i know it come with ramsinks, but the cooler itself does not touch the ram, thus it dosent cool the ram.
Look at the fan and the design. No air goes over the top RAM from it, but it definitely foes over all the bottom RAM. Not that it does that much--with BGA RAM, esepcially, the heatsinks are more to keep a couple spots here and there from getting too hot comapred to the rest of the RAM chip than to keep the RAM's temp down.
