Question about "turning on computer" without a case.
purbeast0
53,653
6,529
I could do the resistor -> LED in parallel though right? Like just to be sure that it's doing what I expect it to do? I never realized how useful an LED would be for these projects lol.
sdifox
100,440
17,944
better to disconnect, see if circuit will work correctly.
sdifox
100,440
17,944
When I turn it on it shoots to like around 4v or so and slowly goes up to 5.17v after about 20-30 seconds.
If it is 4+v it is already logic 1 from the start. And 20-30 sec is way too long to hold the button down. Damn it.
purbeast0
53,653
6,529
Yeah I had the multimeter pins on the 2 before I turned it on. When I turn it on. the screen blanks out for like a very short time and the very next reading is the +4v. I don't get why it slowly goes up to 5v though. Wish I understood this more so I could try different things lol.
sdifox
100,440
17,944
Yeah the capacitors and resistors are slowing down the rise to 5v. I was hoping it would be slow enough for xor (with both input attached) to pass 1 for a short period of time then turn to 0. But it doesn't look like it is doing that. Going to check the spec sheet of the xor again to see what is low enough to register as 0.
Lol 2V registers as 1.
So right now you have 2 resistor and 2 caps in the rc delay right? I need to do some math.
sdifox
100,440
17,944
Try this.
PWRPin-- resistor 1-- resistor 2 -- Capacitor 1 and 2 in parallel -- XOR Input 1
PWRPin -- XOR Input 2
XOR pin 3 --- PWRGRD
purbeast0
53,653
6,529
Yeah that is what I have on the PWRpin going to XOR1.
purbeast0
53,653
6,529
Try this.
Just saw this after I replied. I'll give this a go in a bit after I grill and chill.
Even if we can't get this to work, I appreciate the help and effort you are putting into this.
purbeast0
53,653
6,529
It's fun xd
I agree it is fun. But I want to wrap it up because it's like the last thing I need to do before I can put my cabinet back. I worked on some other stuff for it today too where I had to make a long ass IDE cable (6ft) and then extend a power wire and my gun harness. But since that is wrapped up all I want to do now is wrap this up and I can put my cabinet back in it's spot and clean up.
I mean I could put it back in it's spot now because this game is going to be on the harness that is outside of the cabinet running on those long cables, but it won't be easy for me logistically to take multimeter readings and stuff where it will be sitting, so i'm holding off on that for now.
sdifox
100,440
17,944
sdifox
100,440
17,944
That's too boring, and it wouldn't be clean for my liking. The external game is going to sit on top of one of my Rush 2049 cabinets. I don't want to have to have a wire just to start the motherboard for that game if it's hooked up.
meant as a joke.
Reactions: purbeast0
purbeast0
53,653
6,529
Okay had some time to do it and it isn't working, and when I check XOR1 and XOR3 it is 5.12v immediately when I turn it on. When I turn it off it drains pretty quickly. Same thing when I check XOR2 and XOR3.
I do have the caps so that positive side is running on the resistor side and the negative side on XOR1.
Here is how it's wired up ifspacing works.
Code:
PWRPin --> resistor --> resistor --> cap -> XOR1
                                 |-> cap -> XOR1
PWRPin --> XOR2
GRDPin --> XOR3
sdifox
100,440
17,944
damn it....
you want to try this?
you just need that 555 timer chip, keep using the same resistor and cap to get about 1 second. Pin 4,8 connect to +5V, the 5V with resistor you connect to PWRPIN and PIN3 goes to PWRGRD. Where the 47kOhm resistor is, use 1 of your 10KOhm resistors. Ground after cap is ground from psu.
Needless to say, use the breadboard first.
purbeast0
53,653
6,529
damn it....
I can probably run there later.
It says to use 2 kids of resistors 470 and 47k. Are you saying to use the 10k ones for both of em? Microcenter has the 470 ones but I didn't see 47k.
sdifox
100,440
17,944
you can just use your resistor and cap, the values of resistor and cap affect the timing. If you use the values in that page you get like 5 seconds on which is too long
purbeast0
53,653
6,529
Just went to Microcenter and got the timer thing. I also got more caps and resistors just so I have one without cut legs lol. They are cheap as shit anyways. I also got an NPN transistor since I was there. It was like $3 extra in parts. Do you think the original one with NPN could still possibly work or you think that isn't going to work based on the trouble I've had thus far?
sdifox
100,440
17,944
No go with the timer, the original circuit was flawed, it will flicker.
purbeast0
53,653
6,529
Okay I got it working in the breadboard with just using batteries for +5v and ground. Light stays on for like 1 second or so then cuts off.
I'm going to keep everything in the breadboard and hook it up to the harnesses I made to hook into the motherboard and PSU and cross my fingers lol.
