purbeast0
Oh dang okay lol. Push button is easier but it isn't really user friendly for what I am trying to do at this point so I'm trying to not have to do that if possible.With a NPN, the initial state of pin 3 will be 0, which will result in inputs to XOR being and 0 which gives you 1 on the output of the XOR.
This in turn feeds the base of the transistor and make it go to on state, which allows 5V to flow to the XOR. At this point both input of the XOR are one, resulting in output of 0.
Shit. It's going to flick on again after cap drain. The circuit is wrong. I got to rethink. The temporary connection while maintaining power to the circuit is really tricky.
There is a reason a push button is easy xd.
I do appreciate all your help though! Hopefully you can figure it out lol.
