cbn
- Mar 27, 2009
- 12,968
- 221
- 106
Still I have heard that some drives with TLC NAND coming out (or already released) are supposed to be rated at around 100 P/E.
SSDs using 14nm SK Hynix TLC?
Also, according to the SMART-values of one drive I own that drive would look to be rated at somewhere between 100 and 200 P/E.
Have my doubts as to whether the SMART-values actually happen to be accurate though.
But if 3D QLC NAND doesn't just have similar endurance to but also performs like 15nm TLC NAND then we have already seen that people will accept it, even if combined with a dual channel, single core DRAMless controller.
I want some decent MLC SSDs, with DRAM buffer for mapping tables, and a SATA6G interface. And I want a 1TB one, for $100-120.
What drive is this?
Agreed.
15nm Toshiba or WD/SanDisk TLC (not 16nm Micron TLC or 16nm SK Hynix TLC) has been my own personal standard for lowest end but still acceptable NAND. So if Toshiba 3D QLC can at least match that then I would be interested in it for least a secondary PC.
As long as they don't foul up the implementation like Samsung did with the 840...
----1TB SSD using an odd number of Toshiba/WD 3D QLC dies probably with Marvell 881079 controller (this assuming SMI does not have a SATA 6 Gbps supporting 3D QLC).
^ You're referring to the vanilla 840, and not the 840 EVO right?
AFAIK, Samsung never even bothered to issue a fix for 840 drives, and IINM the fix doesn't work quite right for the 840 EVO either.
That would be the Patriot Blast, it's a 120GB drive and according to SMART it is going to be worn out after about 12-15TB.
But I don't really trust the SMART-values.
You see, it uses Phison S10 as a controller (and the Trion 100 and 150 seem likely to use a slightly modified version of that controller).
Now the Trion 100 had some issues with drives dying pretty early after launch which was fixed by a firmware update.
Not sure what the original firmware was but I would guess it was firmware version 11.0 or 11.1 seeing as the firmware version 11.2 is the most current version for the Trion 100.
Moving on to the Trion 150 it did not have those issues with drives dying after a short time of use, its issue was a more innocuous one, because it was just that the endurance count in SMART went down faster than it should.
That was with firmware version 12.2 and updating to 12.3 fixed that.
Moving back to the Patriot Blast it too had issues with drives dying after just a month or two like the Trion 100 which was fixed with updated firmware.
According to Patriot's website firmware update is recommended if the drive is using 11.0, 11.1, 12.0 or 12.1 firmware versions.
That means it also used to have 11.0-11.1 revision firmware which likely like for the Trion 100 caused drives to die early.
Newest firmware version for the Patriot Blast is 12.2 - as in the same firmware version that the Trion 150 had when the SMART-value for endurance dropped too fast.
And, well - I doubt that it's just a coincidence that firmware revisions were similar when the Patriot Blast seemed to display similar issues to Trion 100 and 150.
So, likely thing is that it's just a firmware issue (that will never be fixed).
TBW for the Patriot Blast is pretty low however so if you're expecting even just a decent bit of wear and to also stay within warranty you may want to look for another drive.
TBW for the 120GB drive is just 19.2TB and for the 960 GB drive it's 76.8TB.
cbn said:----1TB SSD using an odd number of Toshiba/WD 3D QLC dies probably with Marvell 881079 controller (this assuming SMI does not have a SATA 6 Gbps supporting 3D QLC).
Would not exclude that, their controllers are pretty popular and they do release them at a fair rate.
Also one thing to consider is that Marvell and Phison both have controllers supporting 3D QLC NAND (or are likely to in Phison's case) and both also have ECC technologies that they claim may increase endurance by up to 300%.
And SMI has NANDXtend which they also claim can do the same so it doesn't seem that odd to find out that they also have (or will soon have) a controller on the market supporting 3D QLC NAND?
Though perhaps it may be a similar story as with the SM2246 and SM2256, where they first released the SM2256 which supported TLC NAND but later added support for TLC NAND for SM2246.
Noone actually used the SM2246 in a drive with TLC NAND to my knowledge however.
That is interesting you mention that because Phison S10 did not have LDPC ECC.
So with the firmware fix to 12.3, how does Trion 150's (which uses Toshiba 15nm TLC) endurance look like?
OK, I do agree that is likely.
So for Western Digital/SanDisk 3D QLC SATA 6 Gbps SSDs using DRAM buffer we should expect either Marvell 881079 or a SMI controller.
But where does that leave SATA 6 Gbps SSDs using Toshiba 3D QLC? With this Corporation's NAND typically bundled with a Phison controller does that leave only the S11 controller? Or would Phison update the S10 to also work Toshiba 3D QLC?
As far as I know the S11 is their only SATA 6Gbps controller that they currently have that would support 3D QLC NAND and may be the only one that they would use for that.
They may make a controller to replace the S10 since it feels like it would be in need of an update but we will see if that would be in high enough demand to make them feel that it is warranted.
Maybe with 3D TLC NAND, so that you get some faster drives but unsure if they would pair it with 3D QLC NAND.
This is purely conjecture on my part however so take it with a grain of salt.
With the Toshiba A100 and the OCZ TL100 however we have seen them use 15nm TLC NAND along with the S11 which is the dual channel, single core DRAMless controller I was talking about earlier.
Which is why if QLC NAND should perform like 15nm TLC NAND then, well - why shouldn't it also be considered a good combination?
Of course if you want some really big QLC drives however (which is pretty much the only advantage QLC NAND has) a new controller may be needed.
But, as times are moving, Phison wants to go about delivering high performance in a more affordable way, and while doing so, help to drive the transition from SATA to PCIe. How are they going to go about that you may ask? By providing their latest PCIe 3.0 x2 NVMe PS5008-E8 and DRAM-less PS5008-E8T controllers to manufacturers at a similar cost to SATA.
I think 1000 P/E is acceptable. 100-150 P/E is NOT. I don't think I own any SSDs that have only 150 P/E, but I'm not 100% sure.
I own some Adata SU800 Ultimate 128GB with 3D TLC (Micron).
Adata SP550 120GB TLC
Silicon Power S55 120GB TLC
And maybe one other TLC drive.
Also, some Kingston UV300 and UV400, I think.
Do any of those have low P/E cycles? I'll make sure to throw it into a lower-end browser-oriented PC, rather than a power-user / gaming PC.
At Computex 2016, a flash controller manufacturer warned us about DRAMless SSDs shipping with low-endurance planar TLC NAND. 1xnm planar NAND has far less endurance than 3D NAND. The vendor told us that some of the new NAND only has 100 P/E cycles.
Unfortunately, DRAMless SSDs also have a sinister side. Updating the map directly on the flash requires small random writes, which takes a bite out of the SSD's endurance. This is a particularly vexing issue with low endurance planar 2D TLC NAND flash. At Computex last June, one SSD vendor told us about an OEM 2D TLC SSD that will burn through the rated endurance in a little over a year. The SSD has to last a year because of the notebook's one-year warranty, but anything beyond a year's worth of use is up to the user to fix. Tactics like that are the driving forces behind putting cheap DRAMless SSDs in $500 notebooks.
Yes, With Phison S10 working with Toshiba 15nm TLC (despite lack of LDPC ECC) I would think at the very minimum 3D Toshiba TLC would work.
Question is why hasn't Phison updated the S10 now? Could it be they are waiting for Toshiba to release its 3D NAND? (Since Phison is almost exclusively used with Toshiba NAND and they expect it's usage to be even lower volume than the S11)
Or maybe there will be a new SATA 6 Gbps controller (with dram buffer) from Phison? S12? Though, with this mentioned, it looks like in some way the company is trying to position the PCIe 3.0 x 2 NVMe E8 controller as the company's replacement for high end SATA---> http://www.thessdreview.com/ces-2017/phison-demos-entry-level-nvme-e8-controller-ces-2017-update/
With that noted, in post #37 Glaring Mistake mentioned your UV400 had 400 P/E but the Plextor M7V had 2000 P/E. This wide variation even though both SSDs have the same Marvell controller and Toshiba 15nm TLC NAND,
I wonder if this difference, in part, is affected by the higher amount of DRAM on the M7V drive? (Plextor M7V has twice the DRAM (256MB and 512MB) I normally see on 128GB and 256GB SSDs)
P.S See quote below on how dram-less can affect a drive's life. So I wonder does having a smaller (rather than larger) DRAM buffer also affect P/E cycles?
http://www.tomshardware.com/reviews/dramless-ssd-roundup,4833.html
cbn said:Yes, With Phison S10 working with Toshiba 15nm TLC (despite lack of LDPC ECC) I would think at the very minimum 3D Toshiba TLC would work.
What might be more of an issue is that the S10 was made for 2D NAND using Floating Gate while the new NAND is 3D and using a Charge Trap instead.
Because 2D NAND with a Floating Gate behaves differently from 3D NAND with a Floating Gate let alone 3D NAND using a Charge Trap.
That does not explain however why they then have managed to release the S11 if an update to the S10 was delayed due to such difficulties.
Micron 3D NAND still uses Floating gate so maybe there is a chance we could see that being used if the Toshiba 3D TLC won't work with Phison S10?
It still behaves a bit differently than 2D NAND with Floating Gate but that might be easier to implement.
But there's still two things to consider, that is if they want to pair it with a controller using BCH ECC when according to them the endurance of their 3D TLC NAND would then drop from 1500 P/E down to just 500 P/E.
See:
Even if that was not considered an issue the use of non-Toshiba NAND and Phison controllers is a rare one, as you yourself have pointed out.
The new drives are aimed at entry-level and mainstream gaming PCs, and will be based on controllers from Phison using 3D MLC or 3D TLC NAND flash memory from Micron depending on which drive you pick up. The Palit SSDs will be among the first drives on the market that will use a combination of a Phison controller and 3D NAND memory ICs from Micron, but we expect this combination to spread across several SSD vendors in due course.
The supplier of the NAND is also not obvious and could come from different sources. Palit does not disclose who is their supplier, but it is worth noting that Phison usually ships its controllers primarily with memory from Toshiba. We do know that there are Phison PS3111-S11-based reference designs featuring Toshiba’s BICS2 memory (which is not exactly positioned for SSDs by Toshiba) as well as S11 drives with Micron’s 3D NAND memory.
That is good point, then probably Micron 3D MLC would be the only choice for that controller (if such a combination ever actually happened).
P.S. So far I have not seen Phison use Micron TLC (or 3D TLC) in any SSD so far (not even in the reference designs).
And of course, there is always the Patriot Blast (Phison S10 which uses Micron 16nm MLC NAND, not the 16nm TLC NAND).
A very interesting comment Glaring_Mistake made in the other thread--> https://forums.anandtech.com/thread...-various-manufacturers.2510437/#post-38975132
Intel-Micron 3D QLC using a small lithogragphy?
I'm thinking if Intel-Micron decide to go with 3D QLC using the 20nm (or 16nm?) lithography they would probably wait until a suitable controller (with both very strong ECC as well as the ability to handle a very large capacity) emerges.
This being more likely than going with a larger lithography for 3D QLC.
