Q9650 PREVIEW! Taking Test Requests.
OLpal
188
Why is the load line calibration so important & what makes this board worth $60 more than the P5Q-E
Ol'Pal :D
Originally posted by: n7
P5Q Deluxe w/ load line calibration enabled: 1.4v set in bios = 1.39v idle & 1.4v load
Get over to the Intel side already man.
I have an nForce chipset.
It's my A8N32-SLI Deluxe :laugh:...back from when they made decent chipsets.
Anyway, all i'd like to see is max P95 stable clocks @ 1.4v on air, as anything more is too high for 45nm IMO anyway.
n7
21,281
4
Well, it basically prevents vdroop (& vdrop too actually in this case).
Load line off = same kind of vdroop as he's getting :(
Actually my DFI P35-T2R was better for vdroop being not too bad even when not set to prevent that, but the DFI was also pure garbage for clocking 8 GB stably, hence my dumping it.
To avoid taking this too off topic, i'd just say go to Asus's spec pages for those two mobos & open two pages side by side.
There are a number of differences...whether they are worth $60 only you can decide...
aigomorla
21,118
3,645
My DFI isnt garbage tho. :T
DFI LT X38
Only problem im having is it and xfire tho.
And no i cant get 450fsb stable.
as i said the vdroop pushes it to 1.32. i know for a fact most yorkies will require from 1.33-1.36Vcore
n7
21,281
4
Start testing 8 GB DDR2 @ DDR2-1000+ & running HCI Memtest for stability testing...see how much you like your DFI then.
Also, who cares about 450 MHz stable...use your unlocked multi :p
I assume 4+ GHz is stable on air based on what you posted at XS?
Your 4.25 GHz P95 screenie there isn't on air though :p
aigomorla
21,118
3,645
n7 i think you got my processors messed up lol.
This is my QX and she's stable. She's wcging without errors.
Persephone:
http://i125.photobucket.com/al...3/aigomorla/Wprime.jpg
What im testing is freya and its a Q9650.
No unlocked multi on this girl. 9x is about as high it gets.
The retail price per1k is 500ish. I dont remember the exact number.
Freya:
http://i125.photobucket.com/al...aigomorla/Capture3.jpg
She wont hold there because i need about .2-.3 more vcore.
This is a guessimate. I need to do a pencil mod tomorrow and then im gonna retry.
Guys: DISCLAMER
I SERIOUSLY DONT RECOMEND PENCIL MODS.
If you dont know what your doing DONT pencil mod. The Vdroop is there for a reason. Im gonna pencil mod to get vcore @ a low voltage. Im not pushing 1.4V so i want a Vcore somewhere around 1.3875
This is why im pencil moding.
(JAG i said it so dont PWN me please)
aigomorla
21,118
3,645
Originally posted by: Gillbot
keep pushing this thing!
she's benching.
why else you think im up so earily talking to you via pms? LOL.
infact WHAT ARE YOU DOING UP SO EARILY looking at h2o parts?
Oh i thought it would be interesting if i threw the lowest voltage required for stock mhz.
So right now im testing that. :T
aigomorla
21,118
3,645
I'll use this page for stock results and then move it all up to the OP when done.
Anyhow Stock testing completed:
http://i125.photobucket.com/al...orla/Capture-Stock.jpg
Going to 3dmark now
http://i125.photobucket.com/al...aigomorla/3dmark06.jpg
Going x264
Results for x264.exe v0.58.747
encoded 1442 frames, 60.42 fps, 3905.42 kb/s
encoded 1442 frames, 60.34 fps, 3905.42 kb/s
encoded 1442 frames, 60.69 fps, 3905.42 kb/s
encoded 1442 frames, 60.57 fps, 3905.42 kb/s
encoded 1442 frames, 17.97 fps, 3952.85 kb/s
encoded 1442 frames, 18.03 fps, 3952.85 kb/s
encoded 1442 frames, 17.99 fps, 3952.85 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 64.96 fps, 3891.55 kb/s
encoded 1442 frames, 65.10 fps, 3891.55 kb/s
encoded 1442 frames, 64.55 fps, 3891.55 kb/s
encoded 1442 frames, 65.23 fps, 3891.55 kb/s
encoded 1442 frames, 20.05 fps, 3963.43 kb/s
encoded 1442 frames, 20.10 fps, 3963.44 kb/s
encoded 1442 frames, 20.08 fps, 3963.43 kb/s
encoded 1442 frames, 20.12 fps, 3963.43 kb/s
System Details
Name Intel Core 2 Quad
Codename Yorkfield
Specification (Engineering Sample)
Core Stepping
Technology 45 nm
Stock frequency 3000 MHz
Core Speed 3000.0 MHz (9.0 x 333.3 MHz)
FID range 6.0x - 9.0x
Northbridge NVIDIA nForce 780i SLI SPP rev. A2
Southbridge NVIDIA nForce 780i SLI MCP rev. A3
CAS# 4.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 8
Command Rate 1T
Memory Frequency 333.3 MHz (1:1)
Memory Type DDR2
Memory Size 2046 MBytes
Channels Dual
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1
max VID 1.250 V
Voltage sensor 0 1.14 Volts [0x8E] (CPU VCORE)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package Socket 775 LGA (platform ID = 4h)
Temperature sensor 0 44°C (111°F) [0x2C] (SYSTIN)
Temperature sensor 1 51°C (123°F) [0x66] (CPUTIN)
Temperature sensor 2 37°C (98°F) [0x4A] (AUXTIN)
Temperature sensor 0 50°C (121°F) [0x37] (core #0)
Temperature sensor 1 50°C (121°F) [0x37] (core #1)
Temperature sensor 2 48°C (118°F) [0x39] (core #2)
Temperature sensor 3 49°C (120°F) [0x38] (core #3)
Temperature sensor 0 43°C (109°F) [0x2B] (GPU Core)
Temperature sensor 0 48°C (118°F) [0x30] (GPU Core)
SuperPI starting: >.< superpi 32m takes a very long time
http://i125.photobucket.com/al.../aigomorla/SuperPI.jpg
on wPrime: I wish we could post images RAWR.
http://i125.photobucket.com/al...aigomorla/wPrime-1.jpg
That finishes stock testing. Going to take a little break and then start 3.6
Gillbot
28,830
17
My daughter woke me up at 4AM EST so i've been up a while. The wife was BS'ing with my niece till about 1AM last night and I couldn't sleep so it's gonna be a LONNNNNG day. I need a nap!
nyker96
5,630
hey thanks for getting the x264 test results out the door so fast. Just one question, is there a total encode time as the final result? That would make comparison easier.
aigomorla
21,118
3,645
i posted everything the output text file spat out >.<
Theres more?
i'll do the 3.6 and 4.0.
i havent had much time to test fsb yet as well.
aigomorla
21,118
3,645
Originally posted by: HOOfan 1
I request a concrete date of release
the rest of the review?
or the chip?
aigomorla
21,118
3,645
update.
i just finished the pencil mod.
I got the vcore to nice out at .2V droop! WOOT! gonna have fun again.
Im taking predictions on who can guess the proper vcore required for 4.0ghz :T
aigomorla
21,118
3,645
First set of 3.6 benches.
This is Quick Stability with temps. Ambients recorded @ 27.3C, 3DMark06.
http://i125.photobucket.com/al...igomorla/36benches.jpg
Starting x264, SuperPI and wPrime (hope you guys dont mind me condensing things)
encoded 1442 frames, 69.08 fps, 3904.67 kb/s
encoded 1442 frames, 69.34 fps, 3904.67 kb/s
encoded 1442 frames, 61.91 fps, 3904.67 kb/s
encoded 1442 frames, 69.60 fps, 3904.67 kb/s
encoded 1442 frames, 21.48 fps, 3952.97 kb/s
encoded 1442 frames, 20.94 fps, 3952.97 kb/s
encoded 1442 frames, 21.39 fps, 3952.97 kb/s
encoded 1442 frames, 72.67 fps, 3891.55 kb/s
encoded 1442 frames, 72.84 fps, 3891.55 kb/s
encoded 1442 frames, 72.50 fps, 3891.55 kb/s
encoded 1442 frames, 72.55 fps, 3891.55 kb/s
encoded 1442 frames, 23.93 fps, 3963.43 kb/s
encoded 1442 frames, 23.98 fps, 3963.43 kb/s
encoded 1442 frames, 24.03 fps, 3963.43 kb/s
encoded 1442 frames, 23.95 fps, 3963.42 kb/s
System Details
Codename Yorkfield
Core Stepping
Technology 45 nm
Core Speed 3600.1 MHz (9.0 x 400.0 MHz)
CAS# 4.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 8
Command Rate 2T
Memory Frequency 400.0 MHz (1:1)
Memory Type DDR2
Channels Dual
max VID 1.250 V
Voltage sensor 0 1.22 Volts [0x99] (CPU VCORE)
Number of threads 4
Temperature sensor 0 54°C (129°F) [0x36] (SYSTIN)
Temperature sensor 1 58°C (135°F) [0x73] (CPUTIN)
Temperature sensor 2 38°C (100°F) [0x4C] (AUXTIN)
Temperature sensor 0 57°C (134°F) [0x30] (core #0)
Temperature sensor 1 57°C (134°F) [0x30] (core #1)
Temperature sensor 2 56°C (132°F) [0x31] (core #2)
Temperature sensor 3 58°C (136°F) [0x2F] (core #3)
Temperature sensor 0 45°C (112°F) [0x2D] (GPU Core)
Temperature sensor 0 46°C (114°F) [0x2E] (GPU Core)
SuperPI and wPrime to Come.
http://i125.photobucket.com/al...igomorla/superpi36.jpg
Finishes 3.6... gonna go onto 4.0
n7
21,281
4
Oops, i was confused.
Thought your new baby was an Extreme Edition for some reason :confused:
Likely the heat & lack of sleep, sorry.
Nice benching.
nyker96
5,630
Theres more?
umm, if you look at their database of results on the site, it's posted as total run time. there probably a way to convert to it. i will check it out. if you see no other output, you probably captured everything.
aigomorla
21,118
3,645
4.0ghz is loading up pretty high. :X
even under an ifx-14.
yeah my heat sink is getting saturated. I think i need a better fan.
Idontcare
21,110
64
The output file lists the FPS for four runs. Average the FPS and then divide the listed number of frames by the fps rate. Do this for both sections (the fast and slow) and add the times together.
so (69.08+69.34+61.91+69.60)/4 = 67.4825 fps (fast)
and (21.48+20.94+21.48+21.39)/4 = 21.3225 fps (slow)
So we have 1442frames/67.4825fps + 1442frames/21.3225fps = 89.0 seconds for Aigo's run.
Using the Graysky embedded excel spreadsheet calculator (scroll down to middle of page) we see the expected time for a 3.6GHz Yorkfield is 1:29, exactly 89 seconds just as Aigo got.
aigomorla
21,118
3,645
guys i have no loyalty to intel.
i would not edit my data to make them better. :T
i promise you, my data i give you guys is all virgin.
B4 editing or anything.
Anyhow i got 450fsb stable on prime. But i trip the OCCT temp sensor.
The load temps im not happy about. It was loading at around 73C on realtemp.
To some that may not seem a lot, but guys persephone loads at 52ish on higher voltage settings.
so to me, its OUCH. i need to get a better fan or water, so the 4.0 review is on hold for a little bit.
Gillbot
28,830
17
you know the answer to this. water!
aigomorla
21,118
3,645
yeah.. but that makes removal so much more difficult.
That completely defeats the idea of a torture rack. :
But it may come down to that.
The Northbridge on this guy pisses me off to. And no aftermarket solution for it minus 2 waterblocks. So i may have to water the board and cpu.
